Вернуться   Форум FONAREVKA.RU Обзоры фонарей Flashlight Reviews Headlamps. Flashlight Reviews.
Просмотров в теме 12368   Ответов в теме 5   Подписчиков на тему 2   Добавили в закладки 0
Старый 25.06.2010, 17:05 Автор темы   1
Аватар для Dominik
Последняя активность: 24.06.2015 07:00
Поблагодарили: 24 раз(а) в 11 сообщениях
Popcorn Petzl Tikka 2 Plus - review.
Greeting from Poland or CPF
At the shop shelves appeared next refreshed Petzl headlamp. Tikka 2 Plus was redesigned so much that it barely reminds it’s 3 led ancestor, based on power led reserved so far for higher XP model, improves it’s its performance and range of applications. There is only one question, what to chose when you can get the old XP cheaper than new 2 Plus ?
Tikka 2 Plus
Tikka XP
A bit of marketing data
The TIKKA PLUS ² headlamp integrates two light sources for versatility: one white, high-output LED and one red LED. The white LED delivers 50 lumens in maximum mode and lights up to 35 meters. In economic mode, it can reach a burn-time of 140 hours. The red LED provides spare lighting to preserve night vision or to become a blinking light for increased safety, for example in an urban environment, etc. The TIKKA PLUS® ² can be used with lithium batteries to decrease weight or increase performance in cold weather.
Specifications
Colors : E97 PM : mystic gray / E97 PP : pistachio
Operates on three alkaline AAA/LR03 batteries (included)
Compatible with lithium batteries, alkaline batteries and NiMH and NiCAD rechargeable batteries
Degree of protection: IP X4 (water-resistant)
Weight: 83 g including batteries
3-year guarantee
Price : about 45$ / 36 Euro
Impressions
You can see it’s intensive green color far away - fortunately this is not that neon green that you can see on the catalogue photos
Tikka 2 is slightly smaller than the Tikka XP - there is no diffuser, and the casing is more delicate, lamp with batteries weighs 80g compared to 95g of XP’s.
Great advantage of the new Tikka is redesigned closing - withhold catch instead of pressed one, on which you could break nails during battery change. Also the switch is much larger - there will be no problem to push it in the gloves.
After opening there is no problem with accessing to the batteries, by the way you can see a little surprise for too interested users – instead of Torx 6 this time they use Torx 5.
Compared to Tikka XP there is no seals between two parts of the case, it means, that if you put your headlamp into the water the batteries going to be wet. At the top of the casing halves are closely matched, unfortunately, on the sides is a pretty big gap between them. Designation IPX4 - which means rain resistant - should be taken very literally here.
Fortunately, water protection is not so bad as it looks at the beginning, the most vulnerable parts (led & driver) are sealed from the rest of the case by rubber seal. It should keep the headlamp working even with batteries are flooded.
Inside looks…
Unlike the Tikka XP, emitter is directly soldered to the pcb. Bare emitter prevents bin identification and easy replacement. For led cooling new Tikka gets 0 points - star mcpcb is not cooling part so the XP is not better
Since Tikka Plus 2 have almost identical construction as expected XP 2 - so in terms of savings we can expect the same electronics with another driver settings
Power supply
Only 50 lumens, it isn’t so much whet U-binned SSC P4 can give 90 lumens at 350mA – but we have to remember about reasonable work time on 3 AAA cells. According to the manufacturer's data, range of light decreases by more than 50% within 10 hours of use on a high mode, so forget about stabilization – not this time, EOS is still safe.
Код:
Tikka 2 plus - AAA
      V-in   I-In   P-In     V-led  I-led  P-led   Eff.
high  4,46V  289mA  1,29W    3,15V  288mA  0,91W   70,4%
low   4,60V  104mA  0,48W    2,94V  104mA  0,31W   64,1%
Tikka 2 plus - Acu
high  3,85V  183mA  0,70W    3,07V  175mA  0,54W   76,6%
low   3,91V   64mA  0,25W    2,86V   62mA  0,18W   70,3%
In conclusion, the results of Tikka 2 does not differ from its older brother Tikka XP - a very strong start on fresh batteries, then in accordance with the specifications for about 5 hours and goes down till the end… With rechargeables – poor .
How it light ?
With the SSC P4 on board should light quite good - when on it looks like that :
Tikka 2 Plus (SSC P4) vs Tikka XP (Luxeon I) - High
Tikka 2 Plus vs modded Tikka XP (SSC P4 U-bin) - High
Outside
Photos of another modes you can find at my website : http://www.light-test.info/
Summary
I have the impression that Petzl spared some cash on leds selection for Tikka 2 Plus - the replacement is not a big problem – but then why to buy a brand new headlamp ? The 2 Plus have some advantages over the XP – it is lighter, better fits on the head, have red led that you can use for map reading or moving in the premises or even as a safety lamp in the flashing mode. Despite the absence of the diffuser it illuminates the way very evenly – but it is done by the cost of a range.
It have some disadvantages - for somebody it will be advantage that light go through the case and owner is better seen from the side, but for eyeglasses wearer it will be annoying because of light reflexes. Lack of seals in batteries container can cause short-circuit, if you left it flooded for a longer time -headlamp should survive that, but batteries / rechargeables may not. :
Difficult choice... For the occasional user who needs small headlamp “for now” Tikka Plus 2 is certainly a good choice, for outdoor maniac / adventure racer I’ll chose old XP version and mod it right after purchase.
I am looking forward for a new version of XP’s, unless it will be Tikka Plus 2 with diffuser and 2 more modes it will be interesting. If not, modded old & ugly will still rule in the mini headlamps category.
[Исправлено: Admin, 26.06.2010 в 14:00]
Dominik вне форума   Ответить с цитированием Вверх
Старый 25.06.2010, 17:35   2
alefedos
Администратор
Аватар для alefedos
Последняя активность: 04.10.2025 20:00
Сказал(а) спасибо: 108
Поблагодарили: 320 раз(а) в 125 сообщениях
Отправить сообщение для alefedos с помощью ICQ Отправить сообщение для alefedos с помощью Skype™
По умолчанию Re: Petzl Tikka 2 Plus - review.
Спасибо за подробный обзор. Особенно порадовала возможность изучить внутренности
alefedos вне форума   Ответить с цитированием Вверх
Старый 25.06.2010, 17:53   3
vaska
Аватар для vaska
Последняя активность: 07.01.2015 23:43
Сказал(а) спасибо: 20
Welcome, Szemhazai! Glad to see you here.
vaska вне форума   Ответить с цитированием Вверх
Старый 25.06.2010, 18:02   4
Admin
Администратор
Аватар для Admin
Сказал(а) спасибо: 4330
По умолчанию Re: [langtitle=en]Petzl Tikka 2 Plus - review.[/langtitle]
Thank you for the detailed review. In the near future we hope to conduct tests of all the flashlights Petzl.
Старый 25.06.2010, 20:15 Автор темы   5
Dominik
Аватар для Dominik
[lang=en]If you want I can post my reviews of MyoBelt XP '08 and Myo RXP, Tikka 2 XP, Petzl Ultra - they are already on CPF so it's almost ctl+c & ctr+v [/lang]
Enlightened member of pl.rec.rowery
My Bike light’s & Headlamps comparison site. - In polish but picture says everything
Старый 25.06.2010, 21:03   6
Admin
Администратор
Аватар для Admin
Посмотреть сообщение Сообщение от Dominik :
Yes, it would be very interesting. Thank you
Время генерации страницы 0.14189 секунды с 15 запросами
