Просмотров в теме 2377   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 28.12.2015, 23:02 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of AWT IMR26650 5200mAh (Red) 2015
Official specifications:
  • Model: 26650
  • Material: Lithium cobalt oxide
  • Nominal voltage: 3.7V
  • Charge limited voltage: 4.2V
  • Rated capacity: 5200mAh
  • Max Discharge Current: 100A
  • Continue Discharge Current: 75A
  • Cycle life: Over 1000 cycles
  • Standard charge time: 3-5hrs
  • Fast charge time: 2-5hrs
  • Charge temperature: 0°C~+40°C
  • Discharge time: -20°C~+60°C
A high capacity and high current 26650 cell from AWT. The current speifications from AWT's website do not look anywhere near correct.
The two cells are the same at handling loads, but there is a capacity difference, i.e. do not use them in series. They are also significantly below rated capacity.
Conclusion
Significant difference between the cells and both below rated capacity, not the cells I would go for.
Notes and links
The batteries was supplied by AWT for a review.
Время генерации страницы 0.08354 секунды с 15 запросами
