2278
Регистрация: 22.04.2012 Последняя активность: 18.02.2016 02:43
Поблагодарили: 146 раз(а) в 55 сообщениях
--------------------------------------------------------------------------------------------------------------------- Author's Statement for Transparency and Disclosure The test sample/s featured in this article have been provided for technical testing and review by the manufacturer. Test samples are retained by the reviewer following publication of the completed review for the purposes of long term testing and product comparisons. All output figures and test results published in this review are the sole work of the reviewer, and are carried out independently and without bias. Test results are reported as found, with no embellishments or alteration. Though best endeavours are made to maintain the accuracy of test equipment, the accuracy of these results is not guaranteed and is subject to the test equipment functioning correctly. ---------------------------------------------------------------------------------------------------------------------- ![]() Olight have long been known as the makers of search lights by which all others are measured. The SR90 set the benchmark, not for overall output but for throw, and was one of the most wanted lights on the market. Part of that same SR-series, the SR96 is designed around maximum output rather than throw, and as stated in the title, measured in at an amazing 5299lm (outperforming Olight’s specified 4800lm) thanks to its three MK-R LEDs ![]() Taking a more detailed look: The SR96 arrives in a presentation carry case. ![]() It comes assembled, but there is an insulator cutting off the battery so it won’t have turned itself on during transit. ![]() The full contents of the carry case include the SR96, carry strap, spare O-rings and a mains charger. ![]() The battery tube is deeply textured and provides excellent grip. ![]() The tail-cap (which does unscrew) has a button which you press to see the battery level. The level is indicated by four lights. In the centre is a rubber cover that protects the charging socket. ![]() The charger is shown connected here. ![]() The SR96 uses three distinct reflectors within the head. Each has a textured reflector round the MK-R LED. ![]() The MK-R is a large Quad Die LED. ![]() The three medium sized reflectors are not very deep and are textured (exactly as needed for a floody light). ![]() There are deep fins in the main head with plenty of room for air to circulate and cool the head. If you look carefully inside the head (behind the black fins) is the bare aluminium pill. This receives all three reflectors and mounts for the LEDs, and is itself finned. ![]() Another view of the fins and large bare aluminium pill. ![]() The battery pack unscrews from the head. It was inside this join that the SR96 came with a plastic insulator that needs to be removed before using it. ![]() Looking at the contacts on the battery, there is the central positive contact, and a negative contact ring. ![]() And the corresponding contacts in the head. ![]() To get an idea of size, the SR96 is pictured next to the M2X-UT Javelot which is a single 18650 light. The SR96 is substantial, but not a monster. (remember the M2X-UT does have a large reflector) ![]() And another size comparison, the SR96 shown with the Fenix TK75. ![]() There are two gold coloured rings with holes to attach the carry strap. They freely rotate about the SR96. ![]() The strap is nice and wide and very comfortable. You will welcome this if carrying the SR96 all night. ![]() The threads on the battery tube are square cut and fully anodised. What is interesting is that the longitudinal grooves cut for the grip on the battery tube, just nick the threads giving the a slightly serrated look. ![]() The beam Please be careful not to judge tint based on images you see on a computer screen. Unless properly calibrated, the screen itself will change the perceived tint. The indoor beamshot is intended to give an idea of the beam shape/quality rather than tint. All beamshots are taken using daylight white balance. The woodwork (stairs and skirting) are painted Farrow & Ball "Off-White", and the walls are a light sandy colour called 'String' again by Farrow & Ball. I don't actually have a 'white wall' in the house to use for this, and the wife won't have one! Starting indoors, despite the mainly flood orientated beam, there is still a defined hotspot. The spill is nice and wide and great for area lighting. ![]() Before seeing the SR96 outdoors, I need to show you the TK41 I regularly use a reference. This is a good strong 800lm beam with good throw. ![]() And now the SR96, and yes the exposure is exactly the same in both the TK41 and SR96 photo. An almost biblical ‘let there be light’. ![]() Modes and User Interface: Olight have kept things simple with the SR96. It is a search light and has a single button, so has only three brightness levels and a strobe. There is a pseudo-momentary mode. From OFF press and hold the button to switch ON to the last used mode. As long as you hold the button for at least 2s it will go OFF when you release the button. To Switch ON press the button once. The SR 96 switch ON to the last used mode. NOTE: last used mode never includes Strobe. To change modes when ON, press and hold the button to cycle through High -> Low -> Medium -> High etc. Release the button when you have the mode you want. To get strobe, from ON or OFF, double tap the button. To exit strobe, either turn OFF, or press and hold the change mode. Lockout mode is available. To engage lockout, from ON, press and hold the button and allow the SR96 to cycle through the available modes three times, at which point it will turn OFF. Release the button. To exit lockout mode, triple press the button, or remove and reinstall the battery. When locked-out you will notice that when pressing the power button there is a brief flash from the LEDs. Batteries and output: The SR96 uses its own built in 7.4V 7800mAh battery pack. The SR96 has taken my integrating sphere to its limits and has shown heat effects on some measurements meaning I had to rethink how I worked with the SR96. Sphere V2 is being planned right now. To measure actual output, I built an integrating sphere. See here for more detail. The sensor registers visible light only (so Infra-Red and Ultra-Violet will not be measured). Please note, all quoted lumen figures are from a DIY integrating sphere, and according to ANSI standards. Although every effort is made to give as accurate a result as possible, they should be taken as an estimate only. The results can be used to compare outputs in this review and others I have published.
* Beacon and Strobe output measurements are only estimates as the brief flashes make it difficult to capture the actual output value. Peak Beam intensity measured 41200lx @1m giving a beam range of 406m. Parasitic drain at the head of the light is 10.5uA meaning the battery pack would be depleted in 82.57years. This of course is negligible. However this may not be the only source of drain as the tailcap with battery level indicator and charging socket is also a circuit connected to the battery that could draw power. Due to the contact design, I was not able to confirm the parasitic drain. The SR96’s output is impressive. From turn on it is easily over 5000lm and after 5 minutes makes a controlled reduction in output down to 3000lm. This 3000lm output is then maintained up to 40 minutes from turn on. After this it drops to a ‘mere’ 1600lm for a further 2 hours (that ‘mere’ was written sarcastically)!!! This is no slouch even when running short on power. ![]() Troubleshooting This is a new section I am adding to mention any minor niggles I came across during testing, in case the information helps anyone else. No issues were encountered during testing. As per the description of this section, this information is provided in case anyone else finds a similar 'issue' that might be fixed in the same way. The SR96 in use So the SR96 is not an EDC, it is a light with purpose, and you will carry it when you too have purpose. Hand-held it will become fatiguing to hold after around 30 minutes (depending on hand size etc), but you have an excellent strap to use. I do have reasonably large hands (taking XL/10.5 glove size) and I found the SR96 very comfortable to grip. The balance is just right for you to hold it with your thumb over the power button and the weight evenly distributed forward and aft. Intentional or not, this balance works really well. The deep grip pattern has an ideal amount of mechanical grip without being too rough. Considering the Low mode is 555lm, this is not a general purpose light that you are going to use round the house. I would like to have a lower mode as well to make it more versatile, but the SR96 is a powerhouse and hugely effective area light. Taking a look at the beam over a longer range than my standard garden shots, here you can see the tree is well lit, as is the entire area in front of it. The hotspot does give it some reach, though it achieves this by pure output power. ![]() What becomes clearer however, is that this is not a long range search light. Aiming towards a more distant tree, there is very little useful illumination cast onto the tree. Instead the close range flood takes over and limits your vision to the well-lit mid-range distance. (this is a kind of lantern effect where the nearby brightness prevents you seeing further into the distance). This aspect of the beam, its wide bright spill, makes it work very well for use when walking, as it lights up the ground near your feet as well as further ahead of you. ![]() If you want a workhorse super-bright area light, then the SR96 is definitely for you. If you always want MORE light then the SR96 should satisfy that craving (for now at least). Review Summary
If you enjoyed my reviews, please remember to 'Like' me on ******** and follow me on ******* @Subwoofer_CPF
to get all the latest updates and news. You can also find exclusive insights on ********* and Pinterest ![]() |
