Просмотров в теме 2396   Ответов в теме 0   Подписчиков на тему 0   Добавили в закладки 0
Старый 10.11.2015, 10:02 Автор темы   1
Аватар для FlashLion
Последняя активность: 06.05.2017 05:05
Поблагодарили: 124 раз(а) в 35 сообщениях
По умолчанию Nitecore TM16 (four XM-L2 U2, 4000Lm max, 122500cd) REVIEW
Nitecore TM16 is a new powerful flashlight in the popular Tiny Monster series flashlights.
Featuring big reflector with 4 Cree XM-L2 U2 LEDs and maximum output of 4000 lumens with 122500cd peak beam intensity.
The four LEDs require high voltage supply,so the the TM16 is powered by four 18650 batteries,connected in series.
The Nitecore TM16 is relatively compact,with low own weight. I could say,it's easy to carry and does not load you excessively,when walking with it,in hand.
Weight 700gr. with batteries.
180mm long, 89mm head diameter. ~50mm body diameter.
Specifications (taken from manufacturer)
-Utilizes 4 CREE XM-L2 U2 LEDs
-Maximum output up to 4000 lumens
-Features advanced temperature regulation (ATR) technology
-Boasts a peak beam intensity of 122,500cd and a throw distance up to
700 meters
-Dual-switch user interface ensures one-handed easy operation
-Features 5 brightness levels and 3 special modes
-High efficiency circuit board provides max runtime up to 520 hours
-Integrated power indicator light displays remaining battery power
(patented)
-Power indicator’s secondary function displays battery voltage (accurate
to 0.1V)
-Direct access to ultra-low or turbo ensures flexibility and convenience
-Reverse polarity protection prevents damage from incorrectly inserted
batteries
-Stainless steel retaining ring protects the core components from
damage
-Rear tripod connector brings extra functionality
-Toughened ultra-clear mineral glass with anti-reflective coating
-Constructed from aero-grade aluminum alloy
-Sturdy HAIII military grade hard-anodized
-Waterproof in accordance with IPX-8 (two meters submersible)
-Impact resistant to 1.5 meters
-Tail stand capability
Toughened,ultra-clear glass lens with anti-reflective coating.
80mm Diameter of the lens.
Four Cree XM-L2 U2 LEDs.
For reducing the weight,the smooth reflector is made of plastic.
The TM16 is noticeably lightweight for its size,but using a plastic reflector,sacrifices some percents of efficiency.
The LEDs are not perfectly,but quite well centered for a multi-emitter light. The beam is well focused in one point.
A close up look shows the total round-form reflection of the four LEDs.(the picture below).
Closer look...
A picture with the light on the lowest mode.
User Interface.
Five constant brightness modes,plus 3 flashing modes.
UltraLow-Low-Mid-High-Turbo (in this sequence)+ hidden Strobe-Beacon-SOS
Turbo=4000 Lm / High=1780 Lm / Mid 680 Lm / Low=280 Lm / UltraLow=5 Lm
My lumen measurements(with Keeppower 3400 batteries)
Turbo=3940 Lm / High= 1972 Lm / Mid=707 Lm / Low=300 Lm / UltraLow=5,5 Lm
Two momentary switches. One for ON/OFF. One for mode selecting.
Briefly press the ON/OFF switch,to turn ON/OFF. Press and hold it for more than a second to activate UltraLow,directly from OFF.
Press and hold it while the light is ON-this will turn the light OFF and will activate the flashing every three seconds,blue location/indicator light under the switch.This may help you for easier finding the switch in the dark-while the light is OFF. No option for illuminated switch,while the light is ON. The indicator light has no memory and should be activated after each restart.
Pressing the mode switch briefly,while the light is OFF,shows the charge status by the blue switch led. 3 flashes-battery charge over 50%; 2 flashes-voltage under 50%; 1 flash-batteries need to be replaced/charged.
Press and hold the mode switch for more than a second,while the light is OFF,to activate Turbo mode.
While the light is ON,pressing the switch briefly will change the mode. Press and hold it to activate Strobe mode.
Strobe mode can be also activated with double click(mode switch) from OFF.
Switching to Turbo mode directly from any of the other modes is not possible.
There is an instant memory for UltraLow-Low-Mid-High-Turbo modes.
No memory for Strobe-Beacon-SOS modes.
See the actual TM16 user manual- flashlight.nitecore.com
Thew switches can be electronically locked by pressing and holding both,for more than one second,while the light is ON.
Using the dual switch is easy. It is a good size for my fingers and protrude enough for comfortable pressing.
As usual for a side switch,finding it in the dark is hard and requires some time for adjusting the position of the flashlight in the hand.
The blue indicator under the switch may help a little with finding the switch,but not by much. It's very dim and flashing,which makes it not so useful when quick reaction is needed.
Would be great,if the switch was illuminated also while the light is activated.
Close up pictures of the silicone switch cap.
Simple looking,but very sturdy cardboard box with pvc foam inside.
Accessories-Spare O-ring and simple lanyard. Unfortunately,there's no included holster for this model.
One of the anti-roll grooves on the head.
Build quality is as expected,on top level.Great black anodizing,excellent machining-no scratches or defects on my TM16 sample.
The black finish is on the glossy side.
The anti-roll grooves hold the flashlight well on a flat horizontal surface,but not stably enough for sloped surface.
A close-up picture of the tripod mount point at the tail. Standard 1/4 inch thread.
You can also see,the quality of machining is on high level.
Square cut threads.Quality machine work.
Not perfectly anodized,as can be seen on the picture. Tail-cap lock out is not possible,so the not anodized sections of the threads does not matter so much.
Batteries can be inserted without need of battery carrier.
All batteries are electrically connected in series. When inserting them,two of the batteries should be in reverse position of the other two.
Carefully look at the head poles and the stickers showing the right position for each of the batteries.
There are two metal pins on the tail board,that have to be aligned with the two holes in the body.
Every of the negative poles consist two springs for less electrical resistance=easier current flow.
There is a physical reverse polarity protection at the head.Flat top batteries don't contact with the front positive contacts. There is no protection at the tail though,so two button top and two flat top batteries can be used together.Just be sure,they are the same brand and capacity.
Batteries with built-in protection circuit are recommended for flashlights with serially connected batteries.
Electronics performance.
Below is output vs time graph.
I usually activate the light and leave it,without pauses,until the batteries became empty.
The TM16 has a high maximum output and as expected it gets hot,after few minutes on Turbo mode.
According to Nitecore,the TM16 features ATR(advanced temperature regulation) technology-a sensor that should tell the driver that the LED board is hot and need reducing the output,to prevent overheating.
I tested the runtime when activating the light on Turbo mode and leaving it on this mode,until it gets very hot.
The ambient temperature was 25C,with light airflow from air conditioner. I did not use a cooling fan in the beginning.
The TM16 gets warm quickly,so I put a multimeter temperature probe between the cooling fins to get some approximate data for the heating.
This method of measuring is not so accurate,but still gives some useful information.
As with the Nitecore EC4,again I did not manage to activate the temperature control of the TM16. I found the flashlight quite hot,after 5 minutes on Turbo mode.Yes the heat transfer is quite good and spreads the heat quickly to the cooling fins,but also to the battery tube.
In my opinion the flashlight is not comfortable to hold after about 10 minutes. I waited to the 10th minute and activated a small 8cm cooling fan,to help with the cooling.Once the flashlight body is hot,it is not so easy to cool it down to normal temperature,without stopping the light,or selecting Mid,or Low output.
This way of operating of course is expected from a high output flashlight. I am not afraid that much to heat the flashlight,but I am concern of heating the batteries,as this may affect their lifetime,at least. This is why I prefer to keep the flashlight with a normal temperature at the tail.
17 minutes after the start,I turned the light Off,to let it cool down for a second start,this time with a cooling fan on max,from the beginning.
I marked the period without cooling with Noc and the period with cooling ac.
Batteries Keeppower 3400mAh.
Note-the temperature probe was not contacting the aluminum surface directly,so all measurements are approximate.
The initial current draw from four Keeppower 3400 is 2.5A.
As we can see in the graph,after working 17 minutes on Turbo mode,the max output after restart is 10% lower than the initial.
This means,the light is depending on the voltage. Decreasing the voltage,leads to a lower light output.
Feeding 4 emitters with only 4 18650 batteries is hard without designing a special boost driver,or different way of connecting the LEDs(which will require more powerful batteries than used by me).
The Nitecore TM16 will benefit using IMR batteries,because of their better voltage under high current.Use high current batteries for a higher and more stable output.
Again,as in my EC4 review,I did earlier,the driver's low voltage protection does not trigger,if the voltage of all batteries is not equal,just before they are completely empty. In my test,one of the batteries was with triggered protection.Note that the other 3 batteries were discharged to 2,75V(no load).
There was no low voltage warning from the switch's indicator,or by the main light.
The TM16 operates only by the side switches.They turn the light Off electronically,not physically. This means,when turned Off,the driver is actually in Standby mode and still draws some current,to be possible to react on pressing the switch,again. I measured 132 microAmps Standby current.
The switch features also voltage indication.The blue indicator is blinking when you insert batteries and screw the tailcap. For example,4.2 volts are represented with four-pause-two times flashing.
I don't have any of the direct multi-emitter competitors,like the Fenix TK75.
I could compare the TM16 to ThruNites's TN35 and TN32 lights.
The TM16 is lighter,shorter,with a larger diameter reflector.
Nitecore TM16 and Thrunite TN35 are equipped with different LEDs.
4x Cree XM-L2 Vs 1x Cree MT-G2. Different tint-much warmer for the TN35.
The TM16 is equipped with cool white LEDs. Both flashlights have great lumen output and respectable peak beam intensity.
I could say,these flashlights have very well balanced beams for outdoor use.
TM16=4000 Lm max output,122kcd peak beam intensity.
TN35=2800 Lm max output, 70kcd peak beam intensity.
Let's see from the beamshots I took,which looks better to you-the beam from the big,single MT-G2 emitter or the combined light from four XM-L2 leds.
Beamshots
Produced light is clean cool white. No noticeable bluish,or greenish tint.
The beam is well focused,122500cd peak beam intensity.(I measure ~ 125000cd)
Great distance of throw. The spill is also bright and spread to a wider angle,than the single emitter flashlights.
At very close distance,the beam has a typical flower shape. This does not affect the usefulness of the beam,at all.Let's not forget,the TM16 is meant primarily for illuminating far objects,outdoor.
All modes 1/20sec, 1 meter distance
5 meters, 1/6sec
5 meters, 1/50sec
I had to soot with 10000 ISO,beacuse of the huge amount of insects,flying around. This is why the dynamic range of the photos is not that good.
Locked shutter speed and white ballance.
Distance to the trees ~75 meters.
In conclusion,this is my view of the weak and strong sides of the flashlight.
Strong: Great initial output; Great build quality;Good design; Lightweight body; Big reflector; Great beam shape for multi-emitter light; Well focused beam with high peak intensity; May be defined as compact size; I am pleased with the UI; Good mode spacing; UltraLow mode;
Weak: Lumen output is decreasing quickly with regular batteries; Not well set-up low voltage protection; No low voltage warning; No timed output step down-the integrated ATR does not work as desired,for me; Direct access to Turbo mode with the light already turned ON,may be very useful; I prefer aluminum reflectors;
The Nitecore TM16 is a great flashlight for outdoor use. I find it comfortable while using in real life situations,with the normal for all side switch flashlights,slow finding the switch. As any other flashlight/product the TM16 has its strong and weak sides.There is no perfect flashlight for anything and anyone. Hope my review gave you useful information and helps for your choice.
Thanks for reading!
Thanks to Nitecore for providing the TM16 for test and review!
Visit my Blog............ My Pictures on Flickr
FlashLion вне форума   Ответить с цитированием Вверх
Время генерации страницы 0.16053 секунды с 15 запросами
