3952
Модератор своих разделов
Регистрация: 03.07.2010 Последняя активность: 10.10.2022 08:53
Charger Tomo V6-2
![]() This charger is a cheap two slot charger that can charge both LiIon and NiMH. ![]() The cardboard retail box list the specifications on the back. ![]() The box contained the charger and a usb cable. ![]() The charger has a micro usb connector for power input. ![]() The only indication on the charger is a led for each channel, it will flash red when charging and show green when finished with charging. With no batteries in the charger the leds will be off. ![]() The battery slot can handle cells from 30mm to 67.6mm, this means very few protected 18650 cells will fit in the charger. ![]() ![]() ![]() Measurements
Charging LiIon ![]() The charge curve is not a CC/CV curve. The charger stops at a high current and low voltage, this means the batteries are not filled. This might be a good idea, because the charge do not turn current fully off, but continues to charge with a low current (Very bad). ![]() Second channel looks the same. ![]() ![]() Not any difference with other cell capacities. ![]() The older cell looks about the same, except the voltage jumps more up and down due to a higher internal resistance. ![]() With a smaller cell it looks like the charge voltage is up to 4.2 volt due to the pulsing current, but when charge is finished the voltage drops again. ![]() This cell probably has lower internal resistance and the pulsing is not as obvious. ![]() When including the input current it hides everything due to the pulsing. ![]() Removing the input current makes the curve look like all the other charge curves. ![]() Adding a series resistance to the usb power to simulate a long cable or weak charger did not prevent charging, but it is slower. ![]() Same as above, but with input current removed. ![]() I wanted to see what happens if you do not remove the batteries when they are full. The test is done with a 4.35 volt cell and my equipment is programmed to turn the power to the charger off at 4.4 volt. After about 2 days 4.4 volt was reached and the charger turned off, this is very bad. For smaller batteries the over charge will go much faster. ![]() M1: 33,5°C, M2: 33,4°C, M3: 32,9°C, M4: 29,9°C, HS1: 41,2°C When charging LiIon the charger is fairly cool. ![]() The charger need about 2.5 second to start up and uses pulsing on LiIon. Charging NiMH ![]() My NiMH cell is only charged with about half its capacity, this is not very good. It do have some trickle charge and will eventually fill the cell in a day or two. ![]() It is the same on the other channel. ![]() ![]() The Pro and XX is even worse, only 700mAh and 800mAh is filled into them. ![]() The powerex gets some more energy, but far from enough. ![]() 250mAh for an AAA cell, again way to little. ![]() At least it can detect a full battery fairly fast. ![]() Charging two cells is just as bad as one cell. ![]() M1: 55,2°C, M2: 56,9°C, M3: 53,7°C, M4: 48,8°C, HS1: 80,3°C With NiMH the charger is do generate a lot of heat. ![]() The charger need about 2.5 second to start up and uses pulsing. Conclusion The charger can be used for LiIon, but it is very important to remove the cells within a few hours, when the charging is finished. For NiMH it is not really useful because it only partial charges the cells. I will not recommend this charger for any type of battery. Notes Here is an explanation on how I did the above charge curves: How do I test a charger
My website with reviews of charges, batteries and other stuff: http://www.lygte-info.dk/ |
| Поблагодарили: 4 раз(а) |
