9264
![]() Регистрация: 08.08.2011 Последняя активность: 10.06.2025 04:25
Поблагодарили: 159 раз(а) в 53 сообщениях
NEW launched! SKILHUNT DS21 XP-L 900 lumens 18650 EDC flashlight
![]() ![]() ![]() Specifications (ANSI/NEMA FL1-2009 Standards): LED: CREE XP-L Output: Mode 1 Mode 2 Mode 3 Mode 4 900 Lumens 340 Lumens 130 Lumens 9 Lumens Runtime 2.5 h 5.5 h 16 h 120 h Beam Distance:173 Meters Peak Beam Intensity:7500 cd Water Resistance IPX-8 Impact Resistance:1.5 Meter Battery: 1×18650 or 2x CR123A,2x RCR123 Rated Range: 3V ~ 9V Dimension: Length 110mm/4.33inch Head diameter 24mm/0.94inch Body diameter 22.8mm/0.9inch Weight: 52g(without battery) Accessories: Clip, lanyard, magnet replace O-ring, Operator’s manual, Warranty card, Spare O-ring Optional Accessories: Headband,Battery,Battery Charger Features 1. Super bright & lastest CREE XPL LED, High-performance, High-efficiency and energy conservation. 2. Durable aluminum vacuum plating reflector, Efficiency reflection, perfect beamshot, excellent structure and temperature resistance. 3. Toughened ultra-clear glass lens with 99% luminousness anti-reflective coating. 4. Rugged indestructible aluminum body with anti-scratching type III hard anodization. 5. Multi-level dissipating heat design, excellent heat dissipation. Flashlight head integrated construction, high thermal conductivity. 6. Side switch button to transferring mode user-friendly interface to adjust output. 7. Four output levels and strobe, suitable for different environment. 8. Wide input range provides more choices of batteries. 9. Automatic memory function, remember bast used setting and can be preset to specific output mode for instant access. 10. Reverse polarity protection, to protect from improper battery installation. 11. Low-voltage prompts function, the light will flash when the battery is low, remind user replace the battery on time. 12. Engineered anti-slip knurling for a tightly firm grip. 13. Dual recoil absorbing springs, battery impact resistance. 14. Tail stand as a candle-light. 15. Tail hand hole design for lanyard use, to prevent accidental dropping. More details [Исправлено: skilhunt, 19.08.2015 в 18:11] |
Регистрация: 16.01.2011 Последняя активность: 23.04.2019 13:09
Сказал(а) спасибо: 6
Поблагодарили: 37 раз(а) в 21 сообщениях
Просто отличной!
born to hunt, forced to work... |
Регистрация: 01.04.2013 Последняя активность: 13.08.2025 23:02
Сказал(а) спасибо: 1627
Нравится!!!
Регистрация: 07.03.2014 Последняя активность: 20.01.2025 15:33
Сказал(а) спасибо: 5
Skilhunt DS21 LED Flashlight---http://www.gearbest.com/led-flashlights/pp_236834.html
Coupon S21 $33.99В рублях 2244 р. Как думаете, можно брать или еще может подешеветь? |
vitko,
ну через год может и подешевеет . До цены с купоном ) |
Пожилой ветеран
Сказал(а) спасибо: 507
900Лм и 2.5 часа?
Сказал(а) спасибо: 1116
Регистрация: 30.05.2013 Последняя активность: 06.07.2024 12:32
Сказал(а) спасибо: 495
Поблагодарили: 353 раз(а) в 229 сообщениях
Регистрация: 08.03.2011 Последняя активность: Сегодня 07:09
Записей в дневнике: 4 Сказал(а) спасибо: 17684
Поблагодарили: 39930 раз(а) в 14772 сообщениях
Скопирую сюда картинку, чтобы уж была в теме
