Просмотров в теме 2876   Ответов в теме 2   Подписчиков на тему 2   Добавили в закладки 0
Старый 17.08.2015, 16:49 Автор темы   1
Аватар для candle lamp
Последняя активность: 09.06.2017 16:17
Сказал(а) спасибо: 4
Поблагодарили: 403 раз(а) в 87 сообщениях
Arrow Klarus XTQ1 (XM-L2 U2, 1x18650 or 2xCR123A) Review
Klarus has released the XTQ1, features a quiet tailcap switch interface and the XM-L2 U2 emitter. The light runs on 1x18650 Li-ion or 2xCR123A battery source.
Like the RS11, the light comes in a store-shelf display packaging. Included in the packaging was the light with removable clip (attached), lanyard, spare o-rings, grip ring (attached), key-chain, manual.
Manufacturer Specifications & features from Klarus website & manual :
• Patented Ultra-quiet Tactical Switch system with no audible click for ultimate stealth and safety
• Unique flat metal switch with large contact area that is very easy to operate
• Non-visual Touch Operation offers more convenience in the dark
• Momentary-ON function for fast, silent tactical activation that will not disclose user location
• Straight 2 Strobe can be accessed instantly in any situation, producing a variable frequency
strobe to effectively disorientate offenders
• Indented switch design to prevent accidental illumination.
• Dual springs in head and tail for improved drop and shock resistance
• Utilizes a CREE XM-L2-U2 LED, delivering a maximum output of 800 ANSI lumens
• Intelligent control circuits for clear strong light, extended runtime and rapid heat dissipation ability
• Latest optical reflector system gives a beam throw of up to 180 meters and provides a perfect spot
• Elegant Matte detachable stainless steel strike bezel protects the lens and can also be used as an effective self-defence tool
• Toughened ultra-clear glass with anti-corrosion AR coating
• IPX-8 rated waterproof design (underwater to 2 metres), guarantees function in even thewettest weather
• 6061-T6 aircraft aluminum body, ultra-hardened, precision machined
• Able to stand upright for use as a candle
• Reverse-battery protection prevents damage to both flashlight and battery
• Military quality, sophisticated technology, durable and scratch resistant
• CREE XM-L2 U2 LED with a lifespan of up to 50,000 hours
• Three light output modes and one strobe mode
• Working Voltage : 3.0-8.4V
• Battery : 2x CR123A / 1x 18650 (16340 batteries are not recommended)
• Reflector : Textured reflector
• Lens : Toughened ultra-clear glass, AR film
• Material : Aircraft grade aluminum 6061-T6
• Dimensions : 138mm (Length) x 34.9mm (Head) x 22.7mm (Body)
• Net weight : 132g (Excluding battery)
The hard (type III) anodizing is a matt dark brownish gray and consistent throughout with no chips or blemishes to be found on my review sample. Lettering is not very bright white, but legible against the background.
You can take the light apart without any tools and get three parts.
The XTQ1 has a stainless steel crenellated bezel ring are removable, allowing light to shine through when left placed head down. Like the RS11, the bezel ring is not directly touch the o-ring & lens in the head. There is an inner ring similar to bracket between the bezel ring and lens. This structure seems more shock-resistance.
There is a raised contact spring in the head of the light, so flat-top 18650 batteries should work fine in the light. The light has reverse polarity protection to protect from incorrect battery installation (i.e., the electronics of the XTQ1 has in-built reverse polarity protection).
The light uses toughened ultra-clear lens. The purple hue is reflected on it. The aluminum reflector has a light orange peel pattern. Surface finish on the reflector is nice from visual inspection, and well-centered LED sits at the bottom of the reflector cup.
The battery tube (i.e., body) has no knurling. But with all the ridge detail and extra elements around the head and body, overall grip is good. The stainless steel clip-on pocket clip seems to hold on fairly well. It is head-facing, and not reversible. The bundled grip ring is a metal. It can spin even when the tailcap is fully tightened, but it's not inconvenient using the light.
The wall thickness of the body is about 1.9mm, and the light seems reasonably solid.
The screw threads are trapezoidal-cut of good quality. Both male and female threads in the head and tail part are well machined, with being anodized which allows the light to be locked-out when the head or tailcap is slightly loosened. Threads on the both ends of the body mate well with no issues of cross-threading or grinding.
At the tail base, you can see a slightly sunken surface that is very flat. The distinctive aspect of the light is a metal flat switch with no audible click when pressing it. This switch gives you a large contact area and allows the light tailstand perfectly. The switching travel is shorter than average, with average resistance. The tail assembly can be disassembled using snap-ring pliers or a long-nose pliers with ease. You will see the spring contact with a electronic circuit. It means there needs to be a standby current when the tailcap is fully connected.
There is a brief pre-flash when making initial contact of the tailcap with the battery, and a second pre-flash when fully tightened. There is also a brief pre-flash when the tailcap is fully loosened. There is no pre-flash when activating the light in any mode.
User Interface
You can temporarily press for momentary. Press and hold it for more than 1.5 secs to stay locked-on. Turn the light on by a long press for more than 1 sec, and turn the light off in the same way.
Click the switch to cycle through High -> Med. -> Low output and release the switch to select the output.
A double quick press (or double quick click) will activate Strobe, whatever mode the light is in (even Off). Click the switch again to return to the original state.
There is no memory for all outputs and Strobe. The light always comes on in High.
Standby Current Drain
Because the switch is electronic, there is a standby current when the light is fully connected with batteries installed inside the light. I measured this current as 3.9uA. Considering one 2600mAh capacity battery, that would give you around 76 years before one fully charged battery would be completely drained. This is quite negligible, not a concern, but you can break this current completely by slightly loosening the tailcap a little for lock-out, thanks to the anodized threads, when not in use.
From left to right, VicLite 18650(2600mAh) protected, Klarus XTQ1 (XM-L2 U2), Rayus PT10S (XM-L2 U2), Jetbeam 3M Pro (XP-L), Armytek Predator X V2.0 (XM-L U2), Klarus RS11 (XM-L2 U2).
From left to right, VicLite 18650(2600mAh) protected, Klarus XTQ1, Rayus PT10S, Jetbeam 3M Pro, Armytek Predator X V2.0.
Measured Dimensions & Weight
It is very good size to hold. Overall grip is good. Overall build quality is very high.
PWM
There is a visible PWM flicker on Low and Med. mode when shaking the light. But Hi호 has no visible evidence of flicker. I notice there is no buzzing sound on Low and High, but some buzzing sound on Med. only. In my view, this PWM & buzzing sound are not too bad, but acceptable to use the light in real life.
Runtime
XTQ1 steps down on High after about 5 mins runtime on all battery sources. Runtime on 2xCR123A is not shown above, because I erased the related data by mistake. I'm sorry about that. The above runtime labelled as "Accumulated High" is an accumulated runtime for High output (i.e., the light steps down on High to Med. after about 5 minutes, and can go back to High by clicking the tail switch or turning the light off-on).
I remember initial output increased on 2xCR123A relative to 1x18650.
Overall output-runtime efficiency seems fine.
Beamshot
1. White door beamshot (about 50cm from the white door) on max. output on 1x18650 VicLite protected cell
- ISO125, F/8.0, 1/25sec, Auto white balance
- ISO125, F/8.0, 1/100sec, Auto white balance
- ISO125, F/8.0, 1/800sec, Auto white balance
- ISO125, F/8.0, 1/2000sec, Auto white balance
The light has a middle sized bright hot spot. The hotspot is well focused. A soft corona surrounding the hotspot is slightly yellow. There is shadow cut-out on the periphery of the spillbeam, due to the deep crenellated bezel ring. The beam tint is typical cool white on my sample.
2. Indoor beamshot (about 7m from the target) on max. output on 1x18650 VicLite protected cell
- ISO125, F/2.8, 1/10sec, Auto white balance
3. 55m Outdoor Beamshot on max. output on 1x18650 VicLite protected cell
- ISO125, F/2.8, 1sec, Auto white balance
4. 85m Outdoor Beamshot on max. output on 1x18650 VicLite protected cell
Beam pattern is good, Throw is reasonable for the class, given the size of the head and reflector.
Overall Impressions
• Build quality is very high
• No audible click (i.e., quiet) when pressing the tail switch
• Anti-roll indentations on the body
• The light can tailstand stably
• Electrical reverse polarity protection function
• Standby current drain, but quite negligible
• No mode memory (i.e., always comes on in High)
• True flat-top batteries work fine
• Timed step-down feature on High
• Output-runtime efficiency seems fine
• True Moonlight mode is not available
• PWM flickers on Med. and Low mode
• Buzzing sound on Med. mode only
• Brief pre-flash when making initial contact of the tailcap with the battery and when fully tightened
• The beam tint is typical cool white
• Throw is reasonable for the class
Klarus XTQ1 provided by Klarus for review
candle lamp вне форума   Ответить с цитированием Вверх
ko54 (17.08.2015)
Старый 17.08.2015, 17:07   2
PASHA
вечный n00b
Аватар для PASHA
Сказал(а) спасибо: 5257
По умолчанию Re: Klarus XTQ1 (XM-L2 U2, 1x18650 or 2xCR123A) Review
Well, is it a new tendece to do a big, massive tailcap? Let's done it larger than head
Старый 18.08.2015, 13:38 Автор темы   3
candle lamp
The tailcap is bigger than other lights in this class. Instead, it makes you easy to access to the switch, even putting on your gloves.
Время генерации страницы 0.11603 секунды с 15 запросами
