1897
Модератор своих разделов
Регистрация: 03.07.2010 Последняя активность: 10.10.2022 08:53
Vapcell IMR18350 700mAh (Purple)
![]() Official specifications:
![]() The low capacity 18350 from Vapcell, the do also have a 900mAh version. ![]() ![]() I got two different cells, one is flat top, the other is button top, this usual means a small difference at high currents (Button top usual has a slightly bit more resistance). ![]() ![]() ![]() This does not look good, they do not track, they have both different capacity and resistance and that difference is not due to button/flat top. One of the cells can handle 10A, the other can only handle 5A and only with difficulties. ![]() ![]() ![]() ![]() ![]() ![]() Conclusion The A cell has fairly acceptable performance, but with this much variation between the two cells I will call this cell a bad choice. Notes and links The batteries was supplied by Vapcell for review. I did not mix the 700 and 900 cells, both 900 cells has above 900mAh, there is more about them later. Note from VapCell: All our 18350 batteries are out of production. Please ignore the specification. How is the test done and how to read the charts How is a protected LiIon battery constructed More about button top and flat top batteries Comparison to other LiIon batteries
My website with reviews of charges, batteries and other stuff: http://www.lygte-info.dk/ [Исправлено: HKJ, 14.08.2015 в 18:57] |
m72 (10.08.2015)
