Просмотров в теме 4416   Ответов в теме 1   Подписчиков на тему 2   Добавили в закладки 0
Старый 04.08.2015, 17:18 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of Sony US18650V3 2250mAh (Green)
Official specifications:
  • Nominal Capacity: 2250mAh (0.2C discharge)
  • Rated Capacity: 2150mAh (0.2C discharge)
  • Capacity at 1C: 2137mAh (average capacity)
  • Capacity at 10C: 2189mAh (average capacity)
  • Nominal Voltage: 3.7V
  • Cut-off voltage: 2.5V
  • Internal Impedance: 31.5mOhm Typ. (measured by AC1kHz)
  • Cycle Performance: 88% Min. of Initial capacity at 500 cycles(5A discharge)
  • Charge Method: constant current constant voltage
  • Charge Up Voltage: 4.2±0.05V
  • Charge Current: 2.15A
  • Charge Time: 2.5h
  • Ambiance Temperature: 23°C
  • Dimensions: 18.35mm(D)*65.10mm (H)
  • Weight: Max.44g
  • Continuous Max. Discharge Current: 10A
A high current cell, but the specifications looks a bit dated.
The discharge curves look very good with both fine tracking and constant capacity at different load up to 10A.
Conclusion
Being a Sony it is a very good cell and a few years ago this would have been a well performing high current cell, but today there are many cells with better performance.
Notes and links
The batteries was supplied by Akkuteile.de for review.
niki2000 (06.08.2015), vorsmann (05.08.2015)
Старый 08.01.2017, 11:12   2
spb-e
Последняя активность: 28.10.2017 13:38
По умолчанию Re: Test/Review of Sony US18650V3 2250mAh (Green)
От 11 А сильно нагрелись до 50 град примерно очканул отключил тест.
spb-e вне форума   Ответить с цитированием Вверх
Время генерации страницы 0.07163 секунды с 15 запросами
