3353
Hello Everyone,
Good news ! Acebeam published New Item Headlamp H10 which used CREE MT-G2 LED. ONE KEY Max output 2000lm work by 1*High Drain 18650 battery, specially used to Camping,Caving,Reading,Cycling,and daily use making you enjoy the real outdoor funs in various environments. Available four colors: Black, Military Green, Sandy, Grey Features: LED: Cree MTG2 Q0 (5000K) with a lifespan of 50,000 hours Max 2000 lumens output using 1*18650 battery(recommend high drain cell). Level 1: 30lms, 60hours; Level 2: 200lms, 4.5hours; Level 3: 500lms, 1.8hours; Level 4: 1000lms, 0.9 hours; Power OFF: 15uA; Working vlotage: 3V to 6V Max runtime: 30 hours Max beam distance: 116 meters. Peak beam intensity: 3400cd Impact resistant: 1.2 meters. Waterproof to IPX6 standard Size:108mm(length)x24mm(head dia)x21mm(tube dia.) Weight: 52g without battery. Aircraft grade aluminum body structure. Premium type III hard anodized anti-abrasive finish. Ultra-clear tempered glass lens with anti-reflective coating. Highly polished orange-peel reflector creates max throw Tactical knurling for firm grip. Streamlined body design. Intelligent highly efficient circuit board design for max performance&long run time. Intelligent temperature controlled light output for user safety. Operation: The H10 has 2 input devices; a two-stage switch and a rotating ring on the head of the flashlight. Half press(stage 1 soft press) the switch for 2 seconds, the H10 is on, rotate the ring to invoke the 4 output modes. Fully press(stage 2 hard press)and keep it pressed then active the max 2000lm, loosen then off, regardless the light is on/off or under which output modes. Best regards Acebeam Team sales@acebeam.com
www.acebeam.com |
