3267
Acebeam recently developed new thrower T20 flashlight with max 1050 meters beam distance . In order to make the flashaholics be the first ones to experience Acebeam new model, we are now collecting Acebeam T20 Global Testing Campaign. Acebeam will select 10 participants to test the T20. Look forward to your participation and support!
Acebeam T20 Description: T20 uses the new CREE XP-L High-Intensity LED, which bring max 1500lm output from Acebeam special circuit designing by two 18650(also can be supplied by one 18650 battery), smooth polished reflector for both smooth out the beam and max. beam distance 1050 meters, also matched pressure switch option for any tactical, hunting demands. ![]() T20 Operation: Push button of the tail cap control ON/OFF. Press the 'round switch' to cycle through Firefly, Low, Medium, High and Turbo. One Key Strobe,when the light is on, press the 'triangle switch' and hold to get Strobe, loosen then off. T25 have momentary-on, press the push button of tail cap, the light is on at the last mode cycled, half press the push button of tail cap, the light is on, loosen then off. Declaration of the campaign Time of application: 19th June 2015~30th June 2015 Form of application: send email to info@acebeam.com, introduce yourself including experience on reviews, which flashlight modes you reviewed before, or contact Acebeam sales if you have good talk already for review. Requirements for the applicant: Individuals who can post their testing reports on more than one internet media or other relevant, such as website, blog, forums of flashlight, outdoor, photography, magazines and newspaper etc.; The contents much include: Description and your personal feeling of the product; Images and video of the products, including appearance. Report publicize effective time: Participants should publicize the report within 20days after receiving the T20, and send the related link to info@acebeam.com . Notice: 1. Acebeam will contact and select participants by sending emails within 24hrs, if no replies received without 48hrs means we are still in considering your status. 2. Acebeam have the ownership to use/forward the report including works, images, videos,etc. 3. Acebeam reserves the right of interpretation of this testing campaign.
www.acebeam.com |
