Просмотров в теме 1750   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 13.06.2015, 19:32 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of Shockli 18500 1100mAh (Cyan)
Official specifications:
  • Nominal capacity: 1100mAh
  • Nominal voltage: 3.7V
  • Discharge cut-off voltage: 2.75V
  • Standard charge: 4.2V 500mA
  • Maximum charge current: 1000mA
  • Continuous discharge current: 15A
  • Pulse discharge current: 20A
  • Initial impedance max.: 18mOhm
  • Cycle life: 500 cycles to 60%
  • Operating temperature: Charging, 0°C ~ 45°C, Discharging, -20°C~60°C
  • Storage temperature: -20°c -35°c
  • Weight: 35g
15mm shorter than 18650 and as usual it cost a lot of the capacity.
There is some capacity difference between the cells, this means they are best used one at a time. They do handle high current.
Capacity is better than rated.
Conclusion
As long as the cells are used one at a time they are acceptable and can deliver a lot of current.
Notes and links
Admin (13.06.2015), m72 (13.06.2015)
Время генерации страницы 0.08088 секунды с 15 запросами
