Просмотров в теме 3608   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 18.05.2015, 20:36 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of Samsung ICR18650-22P 2200mAh (Blue)
Official specifications:
  • Typical Capacity: 2150mAh (0.2C, 2.75V discharge)
  • Minimum Capacity: 2050mAh (0.2C, 2.75V discharge)
  • Charging Voltage: 4.2V±0.05 V
  • Nominal Voltage: 3.62V (1C discharge)
  • Charging Method: CC-CV (constant voltage with limited current)
  • Charging Current: Standard charge: 1075mA, Rapid charge: 2150mA
  • Charging Time: Standard charge: 3hours, Rapid charge: 2.5hours
  • Max. Charge Current: 2150mA
  • Max. Discharge Current: 10A (Continuous discharge)
  • Discharge Cut-off Voltage: 2.75V
  • Cycle life: 500 cycles to 70% at 2150mA, 300 cycles to 80% at 4300mA
  • Cell Weight: 44.5g max
  • Cell Dimension: Diameter(max.): Ø 18.40 mm, Height : 65mm max
  • Operating Temperature (Cell Surface temperature): Charge : -10 to 50°C, Discharge: -20 to 70°C
  • Storage Temperature 1 year: -20~25°C, 3 months : -20~45°C, 1 month : -20~60°C
This is one of the older Samsung cells, the datasheet is marked 2010. With 10A rated current it was a high current cell.
The cell has fairly constant capacity at any load, but there is a small difference in internal resistance.
Conclusion
The cell looks good, but today there are better performing cells on the market.
Notes and links
Admin (18.05.2015)
Время генерации страницы 0.08966 секунды с 15 запросами
