Просмотров в теме 3875   Ответов в теме 1   Подписчиков на тему 2   Добавили в закладки 0
Старый 16.05.2015, 18:53 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of Samsung INR18650-32E 3200mAh (Cyan)
Official specifications:
  • Typical Capacity: 3,200mAh (0.2C, 2.50V discharge)
  • Minimum Capacity: 3,100mAh (0.2C, 2.50V discharge)
  • Charging Voltage: 4.2V
  • Nominal Voltage: 3.65V (0.2C discharge)
  • Charging Method: CC-CV (constant voltage with limited current)
  • Charging Current Standard charge: 960mA
  • Charging Time Standard charge: 5hours
  • Max. Charge Current: 3,200mA (not for cycle life)
  • Max. Discharge Current: 6,400mA (for continuous discharge), 9,600mA (not for continuous discharge)
  • Discharge Cut-off Voltage: 2.50V
  • Cycle life: 500 cycles to 70% with 3200mA discharge, 300 cycles with 6200mA discharge.
  • Cell Weight: 50g max
  • Cell Dimension: Height : 65.2mm max, Diameter(max.) : Ø 18.50 mm
  • Operating Temperature (Cell Surface Temperature): Charge : 0 to 45°C, Discharge : -20 to 60°C
  • Storage Temperature: 1 year : -20~25°C, 3 months : -20~45°C, 1 month : -20~60°C
Samsung is increasing the capacity and this time it is a 4.20V cell, not 4.30V or 4.35V cell. The cell is not for high current usage.
New quality cells, the two cells match nearly perfect. Capacity do vary slightly with load.
Conclusion
The cells are fairly good at keeping high output voltage, even when loaded.
Being Samsung they are very good cells.
Notes and links
blindnick (16.05.2015), Dima.shym (16.05.2015), vvvoland (18.05.2015), Сумской (17.05.2015)
Старый 16.05.2015, 19:01   2
По умолчанию Re: Test/Review of Samsung INR18650-32E 3200mAh (Cyan)
вчера на ru.nkon заказ сделал. по даташиту, тестов не нашёл
Время генерации страницы 0.07551 секунды с 15 запросами
