Просмотров в теме 4407   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 06.05.2015, 20:50 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of Samsung INR18650-25R 2500mAh (Cyan)
Official specifications:
  • Nominal discharge capacity: 2,500mAh
  • Nominal voltage: 3.6V
  • Standard charge: CCCV, 1.25A, 4.20 ± 0.05 V, 100mA cut-off
  • Rapid charge: CCCV, 4A, 4.20 ± 0.05 V, 100mA cut-off
  • Charging time: Standard charge : 180min / 100mA cut-off
  • Rapid charge: 60min (at 25°C) / 100mA cut-off
  • Max. continuous discharge: 20A(at 25°C), 60% at 250 cycle
  • Discharge cut-off voltage: 2.5V
  • Cell weight: 45.0g max
  • Cell dimension: Height : 64.85 ± 0.15mm, Diameter : 18.33 ± 0.07mm
  • Operating temperature (surface temperature): Charge : 0 to 50°C (recommended recharge release < 45°C), Discharge: -20 to 75°C (recommended re-discharge release < 60°C)
  • Storage temperature (Recovery 90% after storage): 1.5 year -30~25°C, 3 months -30~45°C, 1 month -30~60°C
A high current 2500mAh cell.
This is very good discharge curves, the cells tracks fine and capacity do only drop slight at high load (30A is overload and do not count).
Conclusion
This is a very good high current cell.
Comparing it to the green version of the same cell it has better performance, this may be due to a improved cell, but it can also be due to age and/or storage conditions.
Notes and links
avocado (02.10.2015), blindnick (07.05.2015), Garrik (07.05.2015), pash_ (03.10.2015), Сумской (07.05.2015)
Время генерации страницы 0.07930 секунды с 15 запросами
