Просмотров в теме 6209   Ответов в теме 13   Подписчиков на тему 4   Добавили в закладки 1
Старый 04.05.2015, 05:08 Автор темы   1
Аватар для Acebeam Light
Последняя активность: Вчера 13:22
Сказал(а) спасибо: 12
Поблагодарили: 307 раз(а) в 141 сообщениях
Отправить сообщение для Acebeam Light с помощью MSN Отправить сообщение для Acebeam Light с помощью Yahoo Отправить сообщение для Acebeam Light с помощью Skype™
По умолчанию Acebeam new products ! K60 ultra-long throw XHP70 LED Flashlight published
Acebeam new products K60 announced. Ultra-long throw ! Super bright 5000lumens !
Features:
LED: Cree XHP70 LED with a lifespan of 10+years of run time
Max 5000lumens output using (4x 18650 power cell)
Output (select by magnetic ring):
Level 1 : 1lm 1300hours;
Level 2 : 50lm 140 hours;
Level 3 : 700lm 20 hours;
Level 4 : 1700lm 5.5 hours;
Level 5 : 4000lm 1.6 hours;
Level 6 : 5000lm 1.5 hours;
Standby : 65uA
Strobe : 5000lm 3 hours;
Working voltage: 4V - 17V;
Max Runtime: 1300 hours;
Max beam distance: 704meters;
Peak beam intensity: 124100cd;
Impact resistant: 1.2 meters;
Waterproof : IPX-8 Standard (2meters);
Size: 206mm(length) x 88mm(head diameter)*50mm(tube diameter);
Weight: 570g(without batteries);
Aircraft grade aluminum body structure;
Premium type III hard anodized anti-abrasive finish.
ultra-clear tempered glass lens with anti-reflective coating.
Strobe mode for tactical and emergency use
Smooth reflector for maximum distance.
tactical knurling for firm grip
streamlined body design
Mechanical reversed polarity protection design for battery carrier
Intelligent highly effcient circuit board design for max performance and long run time;
Specially designed for military,Law Enforcement, Self-defense, Hunting,Search&Rescue and outdoor activities.
Intelligent temperature controlled light output for user safety
Accessories include:
1x user manual
1x warranty card
1x lanyard
1x holster
2x Replacement O-rings
1x Replacement Tail cap
Caution:
Highly recommend using unprotected high drain battery (ARC18650H-250A) which at least 20A 2500mAh, the circuit might be tripping if use protected one.
Acebeam Team
www.acebeam.com
Acebeam Light вне форума   Ответить с цитированием Вверх
Старый 04.05.2015, 21:02   2
Freind
Последняя активность: 23.02.2024 17:30
Сказал(а) спасибо: 52
Поблагодарили: 50 раз(а) в 43 сообщениях
По умолчанию Re: Acebeam new products ! K60 ultra-long throw XHP70 LED Flashlight published
Как купить и сколько стоит?
Freind вне форума   Ответить с цитированием Вверх
Старый 17.05.2015, 08:55   3
demonnov
Аватар для demonnov
Последняя активность: 23.11.2023 13:13
Дайте на него купончик, очень хочется приобрести
demonnov вне форума   Ответить с цитированием Вверх
Старый 18.05.2015, 06:58   4
Хвостополосатов
Неехидный Котэ
Аватар для Хвостополосатов
Последняя активность: 19.05.2019 06:53
Сказал(а) спасибо: 10
Acebeam Light, Фото как светит есть?
Хвостополосатов вне форума   Ответить с цитированием Вверх
Старый 24.05.2015, 00:29   5
vpr
Последняя активность: 16.02.2019 22:52
Сказал(а) спасибо: 44
Поблагодарили: 31 раз(а) в 28 сообщениях
Посмотреть сообщение Сообщение от Freind :
на ебее по 200 долларов
http://www.ebay.com/itm/Ace...
vpr вне форума   Ответить с цитированием Вверх
Старый 26.05.2015, 16:41   6
Ultrafire
Аватар для Ultrafire
Последняя активность: 04.07.2017 11:53
Да, внушительный фонарь. ЗАценил
Светит тоже отлично, отчасти за счет мятого рефлектора. На дальнобойность еще не тестил правда
[Исправлено: Ultrafire, 26.05.2015 в 16:43]
Ultrafire вне форума   Ответить с цитированием Вверх
Старый 27.05.2015, 05:02   7
demonnov
Аватар для demonnov
Ultrafire, ток через акумы не мерили? Ко мне тоже выехал данный девайс
Старый 27.05.2015, 05:23   8
demonnov
Аватар для demonnov
Кстати он в какой упаковке должен быть? Коробка или алюминиевый кейс?
Старый 27.05.2015, 06:49   9
Ultrafire
Картонная упаковка, такая как в самом начале темы на картинке.
Старый 27.05.2015, 13:19   10
Ultrafire
По размерам K60 такой же как и K50
Старый 02.06.2015, 15:05   11
Cathode
Аватар для Cathode
Последняя активность: 25.11.2023 17:27
Сказал(а) спасибо: 6
Поблагодарили: 154 раз(а) в 69 сообщениях
Вопрос обладателям - как считаете, если есть Imalent DDT40, есть смысл этот приобретать?
Cathode вне форума   Ответить с цитированием Вверх
Старый 03.06.2015, 06:33   12
Ultrafire
Ну тут на вкус и цвет конечно...
Вот вы например зимой (когда чаще всего темно вечером) на Ималенте как будете в перчатках переключать режимы? Перчатки снимать?
Ну ималент конечно будет поменьше по размерам, но всеравно, ИМХО не карманный фонарь.
Старый 03.06.2015, 06:34   13
Ultrafire
Старый 03.06.2015, 06:45   14
Grammaton Cleric
τετραγράμματον
Аватар для Grammaton Cleric
Сказал(а) спасибо: 179
Посмотреть сообщение Сообщение от Cathode :
Imalent DDT40
Сенсорность не пугает? У народа уже ломался.
Посмотреть сообщение Сообщение от Ultrafire :
Так ведь и К60 не наключник.
Время генерации страницы 0.10334 секунды с 15 запросами
