Просмотров в теме 5726   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 02.05.2015, 18:54 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of Samsung ICR18650-22F 2200mAh (Green)
Official specifications:
  • Nominal Capacity: 2200mAh
  • Charging Voltage: 4.2V ±0.05 V
  • Nominal Voltage: 3.6V
  • Charging Method: CC-CV (constant voltage with limited current)
  • Charging Current: Standard charge: 1100mA, Rapid charge : 2200mA
  • Charging Time: Standard charge: 3hours, Rapid charge: 2.5hours
  • Max. Charge Current: 2200mA
  • Max. Discharge Current: 4400mA
  • Discharge Cut-off Voltage: 2.75V
  • Cycle life: 300 cycles to 68%
  • Cell Weight: 44.5g max
  • Cell Dimension: Diameter(max.):18.4mm, Height: 65mm max
  • Operating Temperature: Charge : 0 to 45°C, Discharge: -20 to 60°C
  • Storage Temperature 1 year: -20~25°C, 3 months : -20~45°C, 1 month : -20~60°C
The datasheet for this cell says 2008, i.e. it is a old design, this can also be seen on the limited capacity and current capabilities.
The discharge curves looks good enough, good tracking between the cell when not overloaded.
Conclusion
Not the most interesting battery today, but the cell is good enough within its limited capabilities and it can easily surpass some cheap brands.
Notes and links
Сумской (02.05.2015)
Время генерации страницы 0.11112 секунды с 15 запросами
