2929
Dear All
Great news ! Acebeam released a new item T25. ![]() Acebeam T25 is the unique design and multifunctional flashlight powered by 2*18650 or 2*26650 batteries.Throw 680 meters.Used the latest CREE XHP50 LED,featured max output 3050lumens. The dual switch in the side can realize a fast selection among 5 different brightness modes,Firefly,Low,Medium,High and Turbo.One key strobe for tactical and emergency use.T25 is very lightweight and widely used to Searching,Rescuing,Hunting... ![]() ![]() ![]() ![]() ![]() ![]() Features: Cree XHP50 LEDs with lifespan 20yrs of runtimes Max Output: 3050lumens Battery Type: 2*18650 or 2*26650 Output modes: Firefly: 1 lms (1200hrs) Low: 50 lms (55hrs) Mid: 1000 lms (4hrs) High: 2000 lms (1.6hrs) Turbo: 3050 lms (1.5hrs) Strobe: 3050 lms (3hrs) Working Voltage: 4V-13V Max Runtime: 2000hrs Max beam: 680meters Peak beam intensity: 115800cd Aircraft grade aluminum body structure Premium Type III hard anodized anti-abrasive finish Ultra-clear tempered glass lens with anti-reflective coating Momentary forward click tactical switch Smooth reflector for max light output Tactical knurling for firm grip Streamlined body design Mechanical reversed polarity protected design Intelligent high efficient circuit for max performance and runtime Intelligent temperature controlled light output for safety Impact resistant: 1.2meters Waterproof : IPX-8 Standard (2meters) Size: 258mm(length)*72mm(head diameter)*30mm(tube diameter) Weight: 320g (excluded batteries) Best regards Acebeam Team sales@acebeam.com
www.acebeam.com [Исправлено: Acebeam Light, 30.04.2015 в 17:27] |
