Просмотров в теме 3035   Ответов в теме 0   Подписчиков на тему 0   Добавили в закладки 0
Старый 21.04.2015, 11:13 Автор темы   1
Аватар для subwoofer
Последняя активность: 18.02.2016 02:43
Поблагодарили: 146 раз(а) в 55 сообщениях
По умолчанию Performance Review: NITECORE TUBE USB rechargeable Keychain light
Why a 'Performance Review'?:
I'm not always able to conduct a full review, but have run the technical tests on a particular light. A 'Performance Review' is intended to provide an outlet for this information and a placeholder for further updates and discussion. No Pros and Cons are included as these performance reviews contain only experimentally measured output figures.
As a 'Performance Review', this thread contains the measured output and runtime data.
Author's Statement for Transparency and Disclosure
The test sample/s featured in this article have been provided for technical testing and review by the manufacturer. Test samples are retained by the reviewer following publication of the completed review for the purposes of long term testing and product comparisons.
All output figures and test results published in this review are the sole work of the reviewer, and are carried out independently and without bias. Test results are reported as found, with no embellishments or alteration. Though best endeavours are made to maintain the accuracy of test equipment, the accuracy of these results is not guaranteed and is subject to the test equipment functioning correctly.
A couple of details:
I've been EDCing three TUBEs for a couple of months now and find the guilt free almost weightless lumens incredibly useful. In everyday urban scenarios, these give a useful backup light that almost unnoticeable to carry.
It must be noted that the colour you choose can have quite an impact on their effectiveness in use (also depending on what you want). As you can see here, with a black and clear TUBE on maximum, the clear body lights up like a lantern, and can be distracting. If you want a mini lantern though, it is excellent.
Modes and User Interface:
The TUBE has quick access to the lowest and highest outputs, and a variable output as well.
From OFF, a single click gives you low. Another click within a second gives maximum output. So you can simply double click to get maximum.
Pressing and holding the button enters the ramping output allowing you to select the level you want. This is not memorised and is lost as soon as you switch it off.
Batteries and output:
The NITECORE TUBE uses a built in lipo cell of a capacity around 100mAh.
To measure actual output, I built an integrating sphere. See here for more detail. The sensor registers visible light only (so Infra-Red and Ultra-Violet will not be measured).
Please note, all quoted lumen figures are from a DIY integrating sphere, and according to ANSI standards. Although every effort is made to give as accurate a result as possible, they should be taken as an estimate only. The results can be used to compare outputs in this review and others I have published.
NITECORE TUBE | I.S. measured ANSI output Lumens | PWM frequency or Strobe frequency (Hz)
______Maximum____________________51_________________________________0
________Low_________________Less than 2lm___________________________71.4
_______Variable___________________50-2______________________________3000
Having an electronic switch the TUBE will have drain. With only a tiny 100mAh cell, this could prove a problem unless very low.
The only way to measure this is to take it apart and unsolder the cell. Initially, when measuring the drain, the cell had been disconnected, and the TUBE had not been turned on then off. The drain in this situation was 320uA. At this rate the cell would be fully discharged in 13 days.
Knowing this is not the case in reality, like other NITECORE lights where the initial drain on connecting the battery if significantly higher than once the light has been turned on then off again, this needed another approach. With the multi-meter on uA it could be damaged by switching the light on and off, so I needed a way of connecting the circuit, then short-circuiting out the meter but then maintaining the connection to allow the drain to then be measured. This was done by soldering additional wires and using crocodile clip probes which could be touched together to short out the meter as needed.
Once done, as you can see here the drain drops to negligible. The meter's lowest measurement is 0.1uA, and the current is less than this. From time to time it did show 0.1uA, but was generally lower.
This makes a huge difference. It means that the 100mAh cell would take 114 years to discharge. Safely negligible!
While hooked up like this it gave the opportunity to test the running current. On low this was 2.53mA
And on Maximum it was 0.145A. Though as the cell drains this will drop, it does fit well with the hour long runtime.
Running on Maximum, this is the output graph for a freshly charged TUBE.
If time permits further information and beam shots will be added to this Performance Review in post 2.
If you enjoyed the review, please remember to 'Like' me on ********
subwoofer вне форума   Ответить с цитированием Вверх
PASHA (21.04.2015)
Время генерации страницы 0.11729 секунды с 15 запросами
