Просмотров в теме 3822   Ответов в теме 0   Подписчиков на тему 0   Добавили в закладки 0
Старый 21.04.2015, 10:54 Автор темы   1
Аватар для subwoofer
Последняя активность: 18.02.2016 02:43
Поблагодарили: 146 раз(а) в 55 сообщениях
По умолчанию 'SHOT SHOW Special' Review: Streamlight SIEGE AA Lantern (3xAA)
'SHOT Show Special' Review: Streamlight SIEGE AA Lantern (3xAA)
'SHOT SHOW Specials' are a series of reviews inspired by, or as a consequence of, my visit to the SHOT SHOW 2015.
These may contain photos taken while travelling, and may be of a slightly different format.
Author's Statement for Transparency and Disclosure
The test sample/s featured in this article have been provided for technical testing and review by the manufacturer. Test samples are retained by the reviewer following publication of the completed review for the purposes of long term testing and product comparisons.
All output figures and test results published in this review are the sole work of the reviewer, and are carried out independently and without bias. Test results are reported as found, with no embellishments or alteration. Though best endeavours are made to maintain the accuracy of test equipment, the accuracy of these results is not guaranteed and is subject to the test equipment functioning correctly.
Streamlight's original Siege light was a full size lantern and something I really like the look of. I didn't get my hands on one of them to test, but have got the new baby brother of the Siege, the Siege AA.
The light on test here was a display sample at SHOT SHOW, so I don't have the packaging and the photos may show some signs of use.
Taking a more detailed look:
Normally folded down around the body, the carrying handle / hanging hook is show in the upright position
A feature of the Siege lanterns is the ability to remove the top section with the diffuser. The top diffuser is attached with a bayonet fixing so requires only a quarter twist to release it.
You can then hang the Siege AA using the folding clip found in the base. Overall this makes the Siege AA smaller and the light more direct. This is reflected in the output figures giving the full output. (the diffuser results in a 45% loss of output)
This is a closer look at the dome covering the LEDs. One central white LED and two red LEDs either side of this.
To show the switch illumination, here the Siege AA is on the red output mode. The switch illumination acts as a battery power meter. Going from Green (as shown) to Yellow, to Red as the cells become depleted.
The battery door is keyed to allow it to be refitted in total darkness.
For an idea of size, here is the Siege AA at the end of a batch of lights on test.
From left to right these are: Olight S10R, Olight S15R, Olight S30R, FOURSEVENS Bolt-Action, FOURSEVENS Preon P2, FOURSEVENS MMU-X3R, Streamlight ProTac HL3, MAG-LITE XL200, NITECORE TM06, Lumintop ED20-T, V54 DC25Cvn and the Streamlight Siege AA.
The Siege AA is a really convenient size for travel and easy to pack.
The beam
Being a lantern, its beam pattern is that of, well a lantern. You can see the diffuser creates a lovely even spread of light.
The red output is also nice and even, and here the exposure has been adjusted to show the light. Red output is very dim compared to the white, so do not take this image as representing the White vs Red output levels.
Modes and User Interface:
The Siege AA has a single built-in electric click switch with a very simple interface.
First, to swap between white and red output modes from either ON or OFF, press and hold the button for 2s
If the Siege AA was OFF, it will then come ON to the alternate output colour. If it was already ON it will swap output colour and stay ON.
In RED mode:
From OFF, press the button to enter steady RED output. Within 4s press the button again to change to RED SOS, and again within 4s to turn OFF.
If you wait more than 4s between pressing the button when ON, the next time you press the button it will turn OFF regardless of output mode.
In WHITE mode:
From OFF, press the button to enter steady WHIITE output - Low. Within 4s press the button again to change to WHITE - Medium, again within 4s to turn to WHITE – HIGH, and once again within 4s to turn OFF.
Siege AA has no flashing WHITE modes.
There is no electronic lockout, but the switch is recessed to reduce accidental activation.
Batteries and output:
The SIEGE AA uses 3x AA cells. Testing was carried out with alkaline and rechargeable AAs and performed well with either.
To measure actual output, I built an integrating sphere. See here for more detail. The sensor registers visible light only (so Infra-Red and Ultra-Violet will not be measured).
Please note, all quoted lumen figures are from a DIY integrating sphere, and according to ANSI standards. Although every effort is made to give as accurate a result as possible, they should be taken as an estimate only. The results can be used to compare outputs in this review and others I have published.
Siege AA using Eneloop LSD NiMh AA | I.S. measured ANSI output Lumens | PWM frequency or Strobe frequency (Hz)
_____White – High – No diffuser________________________245______________________________0
_____White – Med – No diffuser________________________123_____________________________250
_____White – Low – No diffuser_________________________48_____________________________250
_____White – High –Diffuser__________________135 (55% of non-diffused)____________________0
_____White – Med – Diffuser__________________68 (55% of non-diffused)____________________250
_____White – Low – Diffuser__________________27 (57% of non-diffused)____________________250
_____________Red______________________________Below Threshold________________________0
As there is an electronic switch we need to consider the parasitic drain. The Siege AA drain is 39.4uA, and using 1900mAh NiMh cells it would take 5.5 years to deplete the cells.
The Siege AA runtime trace was carried out using 3x 1900mAh Eneloop cells on High White output.
The Siege AA in use
The Siege AA feels a really solid bit of kit. The rubber armoured body should shrug off the rigours of normal outdoor use with ease, and being rubber doesn't mark or scratch either itself or the things it comes into contact with.
Fit and finish is excellent and the removable diffuser and battery cap detach and refit smoothly and precisely.
The rubber is very grippy. Not sticky, but soft and grabs the surface it contacts. This anti-slip feature is excellent and allows the Siege AA to be placed on sloping surfaces and won't slip out of your hands.
Although the diffuser creates a significant 45% drop of total output, it is really well designed. Inside it has a conical reflector with a fine 'brushed' type of finish to further diffuse the light. The resulting light cast by this lantern is fantastically even with no artefacts, so the losses are well worth it. If however you prefer the slightly harsher non-diffused output, you will get more light, so can choose a lower output level and get longer runtimes.
A slight disappointment is the use of PWM at Low and Medium levels. Being an 'area light', this means that you will be aware of the flickering as you move about. Had there been no PWM The Siege AA would be almost impossible to beat for a quality, compact lantern (maybe in a Siege AA v2).
The Siege AA's simplicity and versatility is a winning feature and it just does the job it was designed for. Red light, white light, use it free standing, hanging upright or upside-down, with or without the diffuser, you have all the options you might want in a compact easy to feed AA lantern.
Things I like
Compact neat lantern
Excellent diffused light
Rugged, grippy rubber armour
AA powered
Very low parasitic drain
Floats if dropped in water (with diffuser fitted)
What doesn't work so well
Uses PWM for lower modes at 250Hz
Loses 45% of output with diffuser
Only one red output level
No flashing White modes
If you enjoyed the review, please remember to 'Like' me on ********
subwoofer вне форума   Ответить с цитированием Вверх
Admin (21.04.2015)
Время генерации страницы 0.10918 секунды с 15 запросами
