Просмотров в теме 4850   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 20.04.2015, 20:43 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of Samsung ICR18650-30B 3000mAh (Green)
Official specifications:
  • Nominal Capacity: 2950mAh (0.2C, 2.75V discharge)
  • Minimum Capacity: 2850mAh(0.2C, 2.75V discharge)
  • Charging Voltage: 4.35 ±0.03 V
  • Nominal Voltage: 3.78V
  • Charging Method: CC-CV (constant voltage with limited current)
  • Charging Current: Standard charge: 1475mA, Rapid charge : 2950mA
  • Charging Time: Standard charge : 3hours, Rapid charge : 2.5hours
  • Max. Charge Current: 2950mA (ambient temperature 25°C)
  • Max. Discharge Current: 5900mA (ambient temperature 25°C)
  • Discharge Cut-off Voltage: 2.75V
  • Cycle life: 299 cycles to 70%
  • Cell Weight: 48.0g max
  • Cell Dimension: Height : 65.00mm max, Diameter : 18.40mm max
  • Operating Temperature: Charge : 0 to 45°C, Discharge: -20 to 60°C,
  • Storage Temperature: 1 year: -20~25°C, 3 months: -20~45°C, 1 month: -20~50°C
Note the charge voltage, it is +/-0.03 volt tolerance, not the usual +/-0.05 volt.
Test with 4.35 volt charging
These cells are high capacity cells with moderate current capability. The higher voltage means more energy.
The discharge curves looks nice, good tracking and nearly constant capacity. The cell has a little trouble with the 7A track, it heats up a bit and this improves the performance.
Test with 4.3 volt charging
Reducing the charge voltage to 4.30 volt means losing about 100-150mAh.
The slightly lower voltage makes the discharge curve be more load independent.
Test with 4.20 volt charging
At 4.2 volt charging the loss is about 400mAh compared to 4.35 volt.
The independence of load is also present at 4.2 volt.
Conclusion
This cell has a more flat discharge curve than some high capacity cells, this means higher voltage at the last part of the discharge at any charge voltage. The initial part of the discharge will be higher when charged from 4.35 volt (only at low loads).
It is a very good cell, but requires a 4.35V charger for best performance.
Notes and links
For 4.35 volt chargers check my chargers reviews, Xtar has a some: WP2h, VP2, SP1.
Время генерации страницы 0.11627 секунды с 15 запросами
