3431
Регистрация: 24.02.2013 Последняя активность: 26.07.2025 11:59
Сказал(а) спасибо: 144
приветствую вас, уважаемые читатели.
Сегодняшний обзор посвящу универсальному зарядному устройству с неудачным названием FL-2H-LCD-D. ![]() Итак, что за устройство такое, что оно умеет и какие у него особенности ? начнем с тех.характеристик Charging Mode: ● Adopt negative voltage control technology to improve charge efficiency. ● Protect opposite connection and short circuit. (do not display battery symbol and voltage) ● Activate automatically for Li-ion batteries with protection board, which are instantaneous short circuit. For the batteries' voltage below 0.5V, LCD shows NULL ● Two types of charging current: 0.5A, 1A. (according to different capacity) ● Two types of discharging current: 0.25A, 0.5A. (according to different capacity) ● Stainless steel rail is more durable and smooth ● Worldwide voltage, suitable for the whole world ● 12V car adapter is available ● Sound prompt function (slot completes a charging or discharging step, prompt tone rings) ● USB 5V output mode (used as portable charger for mobile or pad etc.) Output Features: DC 4.2V ± 0.02V 0.50A ± 30mA x 2 1.0A ±50mA x 2 DC 1.48V 0.50A±30mA x 2 1.0A ±50mA x 2 Charging Instruction Mode: A.If don’t plug in, LCD shows nothing. B.B. If don't install batteries and plug in, LCD shows all the data and then shows line between NULL, charging current (0.5A) and CHG. C. If put batteries into the slots, the charger can recognize them Li-ion or NIMH / NiCd battery automatically, and show the present voltage and charging capacity and battery symbol jumps forward. (pressing the button momentarily can choose the charging current.) D. When finishing charging, the prompt tone rings. USB Instruction Mode A. When putting 1 Li-ion battery and no other input, the max output current of USB is 1000mA; B. When putting 2 Li-ion batteries and no other input, the max output current of USB is 2100mA; C. When no inputing, please do not reverse the battery, or it will damage the charger. Что же мы видим, и что интересного? 1. Устройство умеет как заряжать так и разряжать как литий так и никелевые аккумуляторы 2. Устройство указывает "влитую" и "вылитую" из аккумуляторов емкость 3. У устройства есть USB выход, его можно использовать как powerbank, причем используются сразу 2 аккумулятора (опция работает и с одним) 4. Нет вентилятора, есть подсветка и спикер Вывод? Да, устройство достаточно уникально. Делает не все что хотелось бы но многое. Ну а об особенностях использования читаем дальше. ![]() устройство пришло в простом кульке (образец для обзора, может быть обычная упаковка отличается). ![]() [IMG]![]() ![]() В упаковке было только зарядное устройство и блок питания. Устройство можно легко разобрать (до некоторой степени). Блок питания на 12 вольт и один ампер. Качество исполнения на четверку, все крепкенько так но не бронебойно как например у зарядников Xtar. ![]() ![]() ![]() ![]() Устройство обладает многофункциональным LCD экранчиком, на котором можно увидеть массу информации. Теперь немного о использовании, так как не все тривиально. 1. Выбор режима работы/тока заряда/разряда один для обоих аккумуляторов. Короткое нажатие на единственную кнопку управления меняет ток заряда с 0.5 на 1 ампер (ток разряда половина от тока заряда) а продолжительное нажатие меняет режим работы с простого заряда аккумулятора на режим измерения емкости. 2. Режим измерения емкости (разряд) не начинает разряжать аккумулятор при его установке, а в начале устройство заряжает до конца аккумулятор, сигнализирует об этом несколькими короткими гудками (динамик отключить программно нельзя) а потом начинает разряжать аккумулятор. В связи с этим у режима измерения емкости есть ограничение - нельзя измерить емкость батареек (не заряжающихся элементов питания). 3. Минимальный ток заряда 0.5 ампер может быть слишком высок для мало-емких аккумуляторов. 4. Экранчик немного завышает показания напряжения. 4.22 на экранчике означают 4.19 на мультиметре. Заряд несколько раз был закончен на честных 4.2 для лития и 1.47 для никеля (надеюсь по -dV). 5. Заряжает/разряжает устройство если и пульсами то очень быстрыми - мультиметр не заметил скачков. Устройство очень слабо греется и не издает никаких запахов. 6. Еще немного о функции измерения емкости - при включении оной аккумулятор вначале заряжается до конца (слышим звуковой сигнал), потом разряжается (опять сигнал) и потом заряжается опять. Не рекомендую проводить операцию когда в доме кто-нибудь спит, звук весьма громкий и назойливый. Я протестировал функцию на литиевом 18650 емкостью 3100 (проверено Опусом) и на Энелупе - емкость лития была указана точно, в случае никеля показал меньше на 150 mAh. В какой именно стадии тестирования находится устройство можно по анимации заряда - традиционно слева направо - заряд, справа налево - разряд. Можно одновременно тестировать никель и литий. ![]() Функция powerbank работает только от литиевых аккумуляторов. 1. USB выход не функционален когда подключено питание 2. На экране нет никакой индикации когда задействована функция powerbank, ее не нужно включать. 3. Максимальный ток, который смог выдать мой экземпляр был равен 0.48 ампера - причем как при использовании одного так и двух аккумуляторов. ![]() ![]() Попробовал разобрать, дальше не решился. Шурупы находятся под резиновыми "ножками" устройства. ![]() после около минутной работы подсветка экрана отключается. Нажатие на кнопку включает подсветку, причем не выполняет никакой функции, только повторное нажатие меняет параметры устройства. Режим зарядника "по умолчанию" - заряд током 0.5 ампер - последний режим/ток не запоминается. Итоги Надеюсь моего обзора вам было достаточно для формирования мнения об устройстве, и принятия решения о нужности его в вашем быту. Устройство неоднозначное, как по мне - первым делом нужно обезвредить пищалку и будет намного лучше. устройство было предоставлено для обзора бесплатно магазином www.gearbest.com на устройство действует скидочный купон FL2HLCDD, цена с купоном будет 20,99 долларов. ------------------------------------------------------------- Спасибо за внимание. Вопросы? Просьбы? Предложения? Буду рад выслушать и помочь по мере возможностей. |
