Просмотров в теме 3859   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 04.04.2015, 11:15 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of LG 18650 MH1 3200mAh (Cyan)
Official specifications:
  • Nominal capacity: 3200 mAh
  • Minimum capacity: 3100 mAh
  • Nominal Voltage: 3.63V
  • Standard Charge: Constant current 0.5C (1550mA), Constant voltage 4.2V, End current(Cut off) 50mA
  • Max. Charge Voltage: 4.2 ± 0.05V
  • Max. Charge Current: 1.0 C (3100mA)
  • Standard Discharge: Constant current 0.2C (620mA), End voltage(Cut off) 2.5V
  • Max. Discharge Current: 10A
  • Weight Approx.: 49.0 g
  • Cycle life: 500 (0.5C charge and discharge)
  • Operating Temperature: Charge 0 ~ 45°C, Discharge -20 ~ 60°C
  • Storage Temperature: 1 month -20 ~ 60°C, 3 month -20 ~ 45°C, 1 year -20 ~ 20°C
This is a cell with high capacity for fairly high loads and with good cycle life.
The matching between the two cell is very impressive and capacity do not drop much with load. I looks like the rated current of 10A is very resonable.
Conclusion
There is not much to say about this cell, it looks like a very good cell and is designed for use with standard 4.2 volt chargers.
Notes and links
Enn (04.04.2015), Сумской (07.04.2015)
Время генерации страницы 0.07564 секунды с 15 запросами
