2097
Модератор своих разделов
Регистрация: 03.07.2010 Последняя активность: 10.10.2022 08:53
Flash AA 4600mAh (Yellow-blue)
What do you get when you buy batteries rated at twice the normal capacity for NiMH? ![]() Official specifications:
![]() Maximum temperature raise at different discharge currents: 1A:+1,7°C, 2A:+4,0°C, 3A:+6,5°C, 5A:+11,5°C, 10A:+13,2°C Capacity is less than 1/3 the rated capacity, I will not call it a surprise. ![]() ![]() ![]() ![]() ![]() ![]() The curves do match fairly well, but the batteries has low capacity and the voltage is lower than eneloops. ![]() ![]() ![]() ![]() ![]() ![]() Conclusion If the batteries had been marked 1300mAh, they would have been good low capacity NiMH batteries. To answer the question from the top: You get cheated. Notes and links How is the test done and how to read the charts Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
My website with reviews of charges, batteries and other stuff: http://www.lygte-info.dk/ |
