Просмотров в теме 2521   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 04.01.2015, 20:34 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of TrustFire TF32650 6000mAh (Black-red)
Official specifications:
  • Model: TF32650 6000mAh
  • Memory Size: It has no memory effect
  • Refills: Supports up to 500 recharges
  • Protected: Yes protected with PCB
  • Capacity: 6000mAh
  • Dimensions: 3,2 x 6,5 (diameter x height)
  • Weight: 138 grams
This LiIon battery is about D cell size (It is slightly longer), this makes it four times a 18650 in volume.
The battery has the rated capacity and the two batteries do track fairly well. The protection does not allow 7A continuous current draw.
Conclusion
Like 26650 batteries the voltage is higher on this battery and it has a bit more capacity than the best 26650, but at twice the volume.
The actual performance is acceptable, but using 3x18650 in parallel would give more capacity using about the same space.
Notes and links
Not many LiIon chargers supports this battery size, some possibilities are Xtar VP4 and Enova All-80.
Compare to 26650 and other batteries
[Исправлено: HKJ, 04.01.2015 в 21:46]
Admin (04.01.2015), wxp (04.01.2015)
Время генерации страницы 0.07799 секунды с 15 запросами
