2134
Модератор своих разделов
Регистрация: 03.07.2010 Последняя активность: 10.10.2022 08:53
Efest IMR18500 1000mAh (Purple) bt 2014
![]() Official specifications:
![]() A 18500 cell with a very high maximum current, the rating is higher than for many 18650 cells. This means the cell has a fairly low capacity. ![]() ![]() ![]() ![]() ![]() They batteries has very impressive high current handling with nearly constant capacity. There is a slight difference in the internal resistance between the two cells, this may be due to my connection or due to the button top. ![]() ![]() ![]() ![]() ![]() ![]() Conclusion These battery has very good high current performance, but the size limits the capacity (If you have 15mm more length, you can get more than twice the capacity). The cells has slight lower performance then their flat top counterpart. With the performance of these cells, I will call it a good battery. Notes and links The batteries was supplied by Efest for review. How is the test done and how to read the charts How is a protected LiIon battery constructed More about button top and flat top batteries Compare to 18650 and other batteries
My website with reviews of charges, batteries and other stuff: http://www.lygte-info.dk/ |
