Просмотров в теме 2227   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 23.12.2014, 18:38 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of AWT IMR18490 1200mAh (Yellow)
Official specifications:
  • Nominal Voltage : 3.7V
  • Capacity: 1100mAh
  • Lowest Discharge Voltage: 2.50V
  • Standard Charge: CC/CV ( max. charging rate 16.5A )
  • Cycle Life: > 500 cycles
  • Max. continuous discharge rate: 5C
This is a high current 18490 cell (18490 is basically the same as 18500)
The two cells has an acceptable match in capacity. The capacity is as specified and fairly stable even at 15A, i.e. the cell is good at high current.
Conclusion
The battery has very good high current performance and capacity is also fine for the current rating.
Notes and links
The batteries was supplied by AWT for a review.
Время генерации страницы 0.07957 секунды с 15 запросами
