Просмотров в теме 2067   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 15.12.2014, 21:35 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of AWT IMR18650 1600mAh (Yellow)
Flat top version (ft)
This is a high current battery with fairly low capacity.
Official specifications:
  • Nominal Voltage: 3.7V
  • Capacity: 2000mAh (35Amp)
  • Lowest Discharge Voltage : 2.50V
  • Standard Charge: CC/CV ( max. charging rate 4.5A )
  • Cycle Life: > 500 cycles
  • Max. continuous discharge rate: 10C
The battery does nice up to 20A with acceptable tracking between the cells and nearly constant capacity, but it cannot do 30A.
Button top version (bt)
The button top version has slightly higher resistance due to the button top. This is only significant well above 10A.
These two cells do also track very nicely.
Conclusion
The battery is a acceptable high current cell, at least up to 20A, but the capacity cannot match the newer high current cells.
Notes and links
The batteries was supplied by AWT for a review.
[Исправлено: HKJ, 15.12.2014 в 22:10]
Admin (15.12.2014)
Время генерации страницы 0.08859 секунды с 15 запросами
