Просмотров в теме 2915   Ответов в теме 2   Подписчиков на тему 2   Добавили в закладки 0
Старый 09.12.2014, 18:30 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of PowerGenix AA NiZn 2500mWh (Green)
Official specifications:
  • Typical capacity: 1500mAh
  • Minimum capacity: 1350mAh
  • Nominal voltage: 1.65V
  • Minimum discharge voltage: 1.1V at 1C or above, 1.3V below 1C.
  • Ambient charge temperature: 0°C - 40°C
  • Ambient discharge temperature: 0°C - 50°C
  • Ambient storage temperature: less than 30 days: -20°C - 50°C, less than 90 days: -20°C - 40°C, less than 1 year: -20°C - 30°C
  • Internal impedance: <20mOhm (1000Hz)
  • Weight: About 25.0g
  • Size: 14.5(D) x 50.5(H) mm max.
Maximum temperature raise at different discharge currents: 1A:+3,0°C, 2A:+5,9°C, 3A:+8,7°C, 5A:+14,8°C
This is a chemistry that was sold as a replacement for NiMH and better suited to replace alkaline, due to the higher voltage. In practical usage the cells has a rather low lifetime, probably because they are over discharged when used as replacement for alkaline or NiMH cells.
The official capacity is not specified in mAh, but instead energy is specified in Wh, probably to hide the fact that they has less capacity than NiMH batteries.
The two cells I have tested are not very well matched and the capacity is not very high. The voltage is much higher than NiMH and alkaline, it is even higher than lithium cells.
The charging uses the same algorithm as LiIon and Pb batteries, but with another voltage, i.e. they require a special charger.
Conclusion
The cells might be useful for some special applications, but as replacement for alkaline or NiMH they are not very good. The higher voltage might damage equipment and the cells will be damaged when discharged to much.
The different in capacity between the two cell I have tested is not very good.
I do not believe the cells are useable as replacent for alkaline or NiMH.
Notes and links
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
Admin (09.12.2014), Vyacheslav Demeshko (09.12.2014)
Старый 11.12.2014, 19:12   2
+Alexp
Аватар для +Alexp
Последняя активность: 08.10.2025 16:36
Сказал(а) спасибо: 137
По умолчанию Re: Test/Review of PowerGenix AA NiZn 2500mWh (Green)
Он не понимает, что они сделаны специально, где нужно и необходимо 1,5V. Выше можно. Но ниже нельзя.
+Alexp вне форума   Ответить с цитированием Вверх
Старый 11.12.2014, 20:08   3
Vyacheslav Demeshko
Аватар для Vyacheslav Demeshko
Последняя активность: 20.05.2022 19:12
Сказал(а) спасибо: 211
Посмотреть сообщение Сообщение от +Alexp :
Он не понимает
не делайте то, что у Вас у самого плохо получается
Zebralight: H600Fw MKII, H51c; Fenix: HL21, HL23, LD12 S2, E05 R2; Princeton Tec: Remix; Byte; Convoy: S2 T5-5C; Spark: SG5 CW; Xtar: WK41 Sirius AA; Petzl: Tikka 2, Tikkina 2; Olight: H1 Nova NW
Vyacheslav Demeshko вне форума   Ответить с цитированием Вверх
BatrakovSV (09.05.2022)
Время генерации страницы 0.08894 секунды с 15 запросами
