Просмотров в теме 10984   Ответов в теме 8   Подписчиков на тему 2   Добавили в закладки 0
Старый 09.12.2014, 12:00 Автор темы   1
Аватар для XENOled
Последняя активность: 10.12.2014 12:07
Поблагодарили: 17 раз(а) в 7 сообщениях
Отправить сообщение для XENOled с помощью MSN Отправить сообщение для XENOled с помощью Skype™
:fona: Stylish LED flashlight, XENO CUBE V8
XENO CUBE V8 is a stylish led flashlight that is with compact size portable, and with aesthetics&quality design eye-pleasing. XENO CUBE is a high end flashlight, moreover a premium gift/collection/decoration.
XENO CUBE V8 a perfect artwork that integrates technique with aesthetics.
Golden ratio is applied to rectangle body of CUBE that the head side divided by the tail side is 1.618, it makes the CUBE looks more eye-pleasing and natural.
Pleasing and natural looking outlook, Exquisite laser logo, interesting construction
Primarily, CUBE is an premium every day carry flashlight that is equipped with the popular newest indestructible CREE XM-L2 led, made of quality stainless steel solid bar, engineered with precision CNC, waterproof, anti-shock, powered by AA*1 size battery(Ni-MH or 14500 Li-ion battery), and so on.
Experiencing the first-class machining tech..Touch feels great.
Surface is further processed by meliculous polish or sand blasting for better handle and visual effect.
For more details, welcome to contact us.
For cooperation, welcome dealers/distributors to push our brand XENO, email me karolwu2009@gmail.comor karol@xenoled.com
www.xenoled.com
Brand name: XENO
Quality high power led flashlight manufacturer
www.xenoled.com
karol@xenoled.com/karolwu2009@gmail.com
XENOled вне форума   Ответить с цитированием Вверх
Старый 09.12.2014, 13:33 Автор темы   2
XENOled
Аватар для XENOled
По умолчанию Re: Stylish LED flashlight, XENO CUBE V8
1.Brand: XENO®
Model No.: E11
Version: V8, XM-L2
2.Specifications
1/.Emitter: CREE High-Power LED,XM-L2 series. 2-CT optional:
XM-L2 1C U2, Color Temperature 5000~8300K,Cool White, MaxOutput550lms or
XM-L2 3B T6, Color Temperature 3700~5000K,Neutral White, MaxOutput510lms or
2/.Rated Input: DC0.8~3.7V;
Battery: Use one AA size battery-a dry cell,Alkaline,Ni-Cd,Ni-MH,14500 Li-ion,LiFePO4.
3/.Output(Related current, OTF lumens, burning time)
Normal: 3-Stage Normal Illumination Variable Output:
*.Using Ni-MH battery:
L:150mA/55lms/4hrs,ULL:20mA/6lms/20hrs,H:350mA/150lms/1hr
*.Using 14500 Li-ion battery
L:1A/370lms/45min ULL:300mA/116lms/2.5hrs H:1500mA/550ms/20min
Hidden: 3-Stage Functional Variable Output:
Strobe(4hrs @ high level output),
LB(15hrs @ low level output),
SOS(9hrs @ low level output)
Re:
1//.Cool White version; L-Low; ULL-Ultra-Low; H-High
2//.Measured with single 2600mAH SANYO eneloop AA Ni-MH rechargeable battery or 800mAH 14500 Li-ion rechargeable battery. Both full recharged and continuous testing to get a burning time.
3//.The experience result will be a little different for the battery of different brand,condition.
3. Features:
1/. XENO HDE 3+3 Engine:
Two Stand-Alone Closed Circulating Regulative System in HDE:
Normal:3-stage normal illumination variable output: Low, Ultra-Low, High
Hidden:3-stage functional variable output-Strobe, LB(Locator Beacon),SOS
Linear LED driver, Not PWM mode.
Non-Flickering and Absolutely Noiseless even at Ultra-Low level.
With Ultra-Low output, more than 20 hrs burning time.
XENO unique Quiet RSL™ technology.
XENO unique GFC(Gamble Free Concept) impact-resistant technology.
Built-in battery inverted-load protection.
Rated InputC0.8~3.7V;
Max Output: 550lms,Max Burning Time:20 hours.
2/.Emitter: CREE High-Power LED,XM-L2 series. 2-Color Temperature is optional:
XM-L2 1C U2,Cool White: to get max output & fit for warm, hot area and season.
XM-L2 3B T6 Neutral White(Outdoor White): for better color rendering.
3/.Battery:Use any AA size battery-a dry cell,Alkaline,Ni-Cd,Ni-MH,14500 Li-ion,LiFePO4.
4/.Finished & Color optional: Ti-Black, Polished, Sand Blasting is optional.
5/.Reflector: Al-Alloy, micro-OP, special for XM-L series LED.
6/.AR Lens: Ultra clear lens with Anti-Reflection coatings on both sides;
precision polish the edge for impact-resistant.
7/.Water proof: IPX8 standard, 5 meters water dunk-resistance.
8/.XENO GFC impact-resistant system:
Double Spring between anode “+” and cathode “-” of the battery for shock proof.
Both spring are 24K-Gold-Electroplate.
LED driver with XENO GFC impact-resistant technology
9/.Fits XENO Genuine Accessory System well(enclosed):
XENO H3GL–-genuine leather holster, special for CUBE.
4. Size & Weight:
Size: length 101mm,quadrate section 21*21mm,
circular arc corner.
Net Weight: 6 oz(170g,battery not included).
Packing Information: Tin box;
G-Weight: 10.3 oz (290g).
Старый 09.12.2014, 13:40 Автор темы   3
XENOled
Аватар для XENOled
photograph album for several versions of XENO CUBE
www.xenoled.com
Brand name: XENO
www.xenoled.com
Старый 09.12.2014, 16:32   4
Очень симпатично! Но не моё.
Старый 10.12.2014, 05:14 Автор темы   5
XENOled
Аватар для XENOled
Hi, Dear Sir, "You deserve to have it! "
Старый 10.12.2014, 11:37 Автор темы   6
XENOled
Аватар для XENOled
Stylish XENO CUBE, a premium Christmas gifts for your friends/family. Welcome to buy quality led flashlight, brand XENO at our Russian partners online shop.
XENO dealers in Russian below:
www.edc24.ru
www.lampter.ru
Brand name: XENO
www.xenoled.com
Старый 07.09.2024, 18:38   7
mikki1973
Сказал(а) спасибо: 174
Поблагодарили: 326 раз(а) в 168 сообщениях
спасибо..заказал..v8
Старый 12.09.2024, 23:33   8
mikki1973
пришел фонарикама! чугуний просто!!! Резьба идет туго по резинке 1,5мм, снял ее и заказал на АЛИ d16х1мм (10шт.) Надеюсь будет лучше закручиваться. Без резинки раскручивается кубик
ID:	283177 Нажмите на изображение для увеличения
ID:	283178 Нажмите на изображение для увеличения
ID:	283179 Нажмите на изображение для увеличения
ID:	283180 Нажмите на изображение для увеличения
Старый 12.09.2024, 23:34   9
mikki1973
v7 всё таки мне нравится больше...цельнее что ли...
Время генерации страницы 0.12034 секунды с 16 запросами
