Просмотров в теме 3416   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 27.10.2014, 14:28 Автор темы   1
Последняя активность: 08.03.2016 14:00
Поблагодарили: 98 раз(а) в 47 сообщениях
Отправить сообщение для hkequipment с помощью MSN Отправить сообщение для hkequipment с помощью Skype™
По умолчанию JETBeam WL-S4, Thrunite Archer 2A v2, Xtar VP4 Charger...
Thrunite Archer 2A v2 Cree XP-L - 2AXPL
Features,
- Upgraded version of the Archer 2A with more user-friendly UI and updated LED.
- Added side switch for easy operation.
- Five modes: firefly, low, medium, high and strobe.
- Momentary “forward clicky” tactical switch.
- U shape groove at the tail for easy activation as well as preventing accidentally activation.
- Reversible and removable stainless steel pocket clip with titanium coating for durability.
- Memory function to set any mode(except for strobe) for immediate use.
Specifications:
- LED: CREE XP-L V6 LED with a lifespan of 20+ years of run time.
- Modes & Run-time: Firefly:0.055lumen(672 hours); Low:17lumen(96 hours); Medium:75lumen(11 hours); High:450lumen(100 minutes); Strobe:450lumen(140 minutes).
- Max output: 450lumen using two AA batteries. Run time: 672hours (Firefly mode)
- Battery: 2 AA batteries(not included), Working voltage: 0.9v to 4.2v
- Max beam distance: 130 meters. Peak beam intensity: 4232 cd.
- Impact resistant: 2 meters, Waterproof to IPX-8 Standard (1.5meters)
- Weight: 75g without battery.
- Dimensions: 160mm in length, 23mm bezel diameter.
JETBeam WL-S4 MT-G2 2600lm Flashlight - JBMTG2
Features:
LED: Cree MT-G2
Maximum output: 2600 lumens
Max beam distance 380meters
Precise aluminum reflector
Toughened ultra-clear mineral glass with anti-reflective coating
Aero grade aluminum alloy with Type III hard-anodized anti-abrasive finish of grey
Power by RCR123A*4/CR123A*4 or 18650*2
Switch: Dual switch (tail and side)
Impact-resistant accords with US MIL-STD-810F (1.5 meters).
Size: Diameter 63mm (Head), 25.4mm (Body), 26.5mm (Tail), Length: 242mm
Weight: 272g (without batteries)
Output and Runtime:
Turbo 2600lm (2.8hrs)
High 1050lm (3hrs)
Mid 360lm (6hrs)
Low 100lm (13hrs)
Ultralow 5lm (180hrs)
[img]!http://img.auctiva.com/imgdata/5/0/6/1/5/7/webimg/794249864_o.jpg[/img]
Xtar VP4 Four Channel Charger with selectable charging current
XTAR VP4 is an intelligent four channels completely independent lithium ion LCD battery charger. Charging current can be adjusted automatically according to different channel, the user can also manually choose the current by the current switch button. The 120°angle high definition VA real time display, precision of battery cutting-off voltage, battery power indicators and optional currents, etc., whenever you know the battery charging status. If you want to buy a charger which is multislot, multi charger currents and can see charger status,VP4 charger will be your best option! The charger is compatible with 10440/16340/14500/14650/17670/18350/18490/18500/18650/18700 and/or two 22650/25500/26650 lithium batteries Features: - Compatible with IMR lithium battery - Each channel is independent - Three-stage charge algorithm(TC-CC-CV) - Three charge current options (0.25 A, 0.5 A, and 1.0 A) - Soft-start function, to avoid damage from large charge current while charging. - Automatically cut off when the battery is charged fully - Precision cut-off voltage at 4.2V - Compatible with small capacity battery - Over heat protection - LCD displays each battery real time statues - Use high power intelligent step-down DC - DC circuit, greatly reduce the energy loss; - Built-in reverse-polarity and short-circuit protection circuit - Use fireproof material for the shell - 0V activation function can wake up the over-discharged/sleeping batteries - 120°angle high definition VA screen to display the charging current ,voltage and power indicator, you can see the charging status from any angle of view. - Certified by CE, RoHS
hkequipment
Web : http://www.hkequipment.net
MSN : info@hkequipment.net
Skype / ******* : hkequipment
Paypal : pay@hkequipment.net
hkequipment вне форума   Ответить с цитированием Вверх
Время генерации страницы 0.09549 секунды с 15 запросами
