Просмотров в теме 2185   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 04.10.2014, 10:54 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of Basen 18500 1100mAh BS186G (Black)
Official specifications:
  • Type: BS186G(High Drain)
  • Capacity: 1100mAh
  • Voltage: 3.7V
  • Style: Flat top
  • Protected: No
  • Max.discharge current: 22A
  • Weight: 33±1g
  • Size: Diameter: 18.16mm; Length: 49.75mm
This is a 18500, these batteries usual has fairly low capacity and this battery is no exception, but it can deliver a lot of current.
There is good tracking between the two cells and the capacity is nearly constant independent of load, even at 20A
Conclusion
These battery has very good high current performance, but the size limits the capacity (If you have 15mm more length, you can get more than twice the capacity).
With the performance of these cells, I will call it a acceptable battery.
Notes and links
The batteries was supplied by Basen for a review.
ualery (04.10.2014)
Время генерации страницы 0.08101 секунды с 15 запросами
