Просмотров в теме 2987   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 30.09.2014, 20:29 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of AWT IMR18650 2000mAh (Yellow)
Official specifications:
  • Rated Capacity: 2200mAh (0.5CA Discharge)
  • Rated Voltage: 3.7V
  • Internal Resistance: <100mOhm (with PTC)
  • Cut-off Discharge Voltage: 2.75V
  • Charge Upper Limit Voltage: 4.20±0.05V
  • Charging Time(Std): 4.0hours
  • Standard Charging Circuit: 0.2C A
  • Charging Circuit: 0.5C A
  • Standard Discharging Circuit: 0.2C A
  • Fast Discharging Current: 0.5C A
  • Max Discharging Current: 2C A
  • Weight: about 45.5g
  • Height: 65mm
  • Operational Temperature: charge (0 ~ 45°C), discharge (-20 ~ 60°C)
  • Storage Temperature: within 1 month (-20~ 50°C), within 3 months (-20~ 40°C)
A high current 18650 battery. According to specifications I got from AWT the 30A are pulse rating and 15A is continuous rating.
The batteries cannot deliver 30A. The batteries has about the same capacity, but there is a difference in internal resistance.
Conclusion
The battery can deliver a lot of current, but the difference in internal resistance means that it is a bad idea to use them in series especially at high current.
Notes and links
Admin (30.09.2014), ualery (30.09.2014)
Время генерации страницы 0.08084 секунды с 15 запросами
