3534
Регистрация: 12.07.2014 Последняя активность: 06.05.2017 05:05
Поблагодарили: 124 раз(а) в 35 сообщениях
ThruNite has updated their Neutron models.
The flashlights are now compatible with different size batteries and come with an extension tube for doubling the power source. The New Neutron 2A v2 pretend to be the brightest flashlights in AA size powered by 1NiMH and 14500 as well. 460 lumens from a single NiMH battery is really impressive achievement. The 2Av2 can be used in 1xAA or 2xAA configuration. Working Voltage: 0.9-5V ![]() Black finish. Hard anodized aluminum body. ![]() The switch is electronic push button,placed low in the body compared to some other flashlights with a side switch. It doesn't protrude too much and in my opinion is relatively hard to press it accidentally. Of course any electronic side switch could be pressed accidentally by hard object or under too much accidental pressure. If you afraid of accidental activation,you can lock out the head. The UI has no locking option. As many other side switches,finding the switch in the dark requires some time. The switch has no easy to find by touch shape and could be too small for big fingers. There is no click sound. ![]() Excellent knurling. Just the right depth-not too light and slippery,not too aggressive to scratch everything around it. ![]() The tail is flat,allowing good tail-stand option. The pocket clip is removable.Quite stably attached for this type clips. ![]() Standard for ThruNite packaging. Very nice cardboard box. Accessories-Pocket clip,Very good Holster,Extending battery tube,Spare O-rings. ![]() Dimensions: - Length: 96mm 1xAA, 146.5mm 2xAA - Diameter: 25.4 mm(head) - Weight: 59gr. 1AA size, 86gr. with a NiMH battery 76gr. 2AA size, 129gr. with NiMH batteries The 2C v2 has a good anti-roll design. ![]() ![]() ![]() ![]() Size comparison. Sunwayman S10R,Klarus RS16,JetBeam RRT0,Neutron 2Cv2,Neutron 2Av2, Keeppower 3400 ![]() JetBeam RRT0 with extender, ThruNite TN12, Olight ST25,ThruNite 2Av2, AA NiMH battery ![]() ![]() Well machined parts. ![]() Physical reverse polarity protection to protect from improper battery installation. Aluminum body with quite thick walls. All parts fit well,without gaps. ![]() ![]() ![]() ![]() Triangular cut threads with rounded tops. Anodized. Well greased O-rings. ![]() CREE XM-L2 U2 LED Perfectly centered LED on my sample. Aluminum smooth reflector. Toughened ultra-clear glass lens with anti0reflective coating. ![]() ![]() Identical reflector with TN12(2014) and eutron 2Cv2.All lights with a Cree XM-L2 LED. ThruNite TN12(2014)- ThruNite 2Cv2- ThruNite 2Av2- Skilhunt DS10 ![]() Quite good grip. ![]() User Interface. The Neutron 2A v2 shares the same UI with its brother Neutron 2C v2. Same side switch,same mode sequence and operating.My opinion of the UI is the same for both models. 5 brightness modes. 3 main modes High-Mid-Low repeating in sequence High-Mid-Low-Mid-High-Mid... Switching ON/OFF by short click. Press and hold the switch to cycle between all modes. Very smooth transition between all different modes. Very pleasant to the eyes,without sharp changes with stepping from High to Low or Low to High,which is hard for the eye adapting. Mode changing reminds me on a flashlight with magnetic ring with infinite brightness control,not only because of the mode sequence,but also because of the smooth transition mode to mode. There are two hidden modes-Turbo and Moonlight. Turbo is accessible by double click from Off. Press and hold the switch from Off to activate Moomlight mode. There is an instant memory for the main modes High-Mid-Low. Turbo and Moonlight are not being memorized. There's no Strobe or SOS. The light is current regulated on all modes with no any sign of pwm. Definitely one of the best User interfaces I have tested.:thumbsup: Easy and quick to use. Instant memory and good choice of modes are welcome for any EDC light. Short video presenting the UI and design specifics. (turn on annotations)
Max lumen output according to manufacturer: 1xAA NiMH - Output mode/Runtime: - Turbo : 480 lumens /80 minutes - High: 230 lumens / 90 minutes - Mid: 70 lumens / 3 hrs - Low: 11 lumens / 72 hrs - Moonlight:0.04 lumens/33 days 2xAA NiMH - output mode/Runtime: - High: 230 lumens / 215 minutes - Mid: 70 lumens / 7 hrs - Low: 11 lumens / 7 days - Moonlight:0.04 lumens/68 days - Peak Beam Intensity: 8540cd - Max beam distance: 185m The ThruNite 2A v2 is impressively bright on Turbo mode for a AA light. My lumen measurements: 1xAA NiMH Turbo 460 Lm High 221 Lm Mid 67 Lm Low 9.8 Lm 2xAA Turbo 750 Lm 1x14500 Low 7.66 Lm Mid 65.7 Lm High 221 Lm Turbo 850 Lm The Neutron 2A features a Low voltage warning combined with a low voltage protection. The low voltage protection performed excellend in all tests protecting the batteries from overdischarging. The warning(flashing) function doesn't work so consistently and sometimes fails to work. For example in the 2xAA runtime curves is not visible any flashing,but when I insert nearly empty batteries the low voltage warning is activating after a few moments. Due to the electronic switch,the 2Av2 draws a low Standby current 60 µA. Threads are anodized=lock-out is possible. This is a runtime graph. Displays the Lumen otput for the time in minutes. I did not test the runtime on Turbo mode with a 1x14500. Due to the high current in this Mode is recommended using a IMR/high current draw compatible battery. There is a brightness step down 4 minutes after activation to protect the flashlight from overheating. The Neutron 2A performs impressively well,maintaining constant brightness after the step down with decreasing the output in the last minutes on 1xAA NiMH battery.:thumbsup: ![]() (click on picture to see it larger) Beam of the Neutron 2A is almost the same as the Neutron 2Cv2 ThruNite TN12's beam (click to see it). Both flashlights use Cree XM-L2 LED and visually the same reflector. The LED on my sample gives a cool white light with no greenish or bluish tint. As expected from a smooth reflector,produced beam is not clean of artifacts and transition from hotspot to spill is not so smooth. ![]() 1 meter 1/20sec white wall 1AA NiMH battery ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() 1 meter 1/250sec white wall 1AA NiMH battery ![]() ![]() ![]() ![]() ![]() ![]() 1meter, 1/20sec 1x14500 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() 1 meter 1/250sec 1x14500 ![]() ![]() ![]() ![]() ![]() ![]() 5 meters, 1/6sec 1xAA NiMH ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() 5 meters, 1/50sec 1xAA NiMH ![]() ![]() ![]() ![]() ![]() ![]() ![]() 5 meters, 1/50sec 1x14500 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Reserved for corrections and opinion after longer time of use. Thanks for Reading! Neutron 2Av2 provided by ThruNite for test and review. [Исправлено: FlashLion, 25.04.2015 в 21:35] Причина: Video |
