4690
Регистрация: 02.06.2012 Последняя активность: 21.04.2015 12:00
Поблагодарили: 42 раз(а) в 22 сообщениях
Don't forget to click "Like" after the page loads! Nitecore is one of the leaders in the high-end flashlight industry, with lights of all sizes and purposes. Now, they've produced a long distance thrower with an OLED display, the longest distance thrower that I know of from a big manufacturer, by using the high output and round Luminus SBT-70 emitter in a huge reflector. Presenting the Tiny Monster 36: ![]() Thanks to Nitecore for providing the TM36 for review. I’ll be reviewing the TM36 in two sections: first, I’ll discuss the light objectively (the facts about the light itself), then I’ll discuss the light subjectively (my impressions about the light's performance when used for specific applications). If you have any other specific applications you'd like the light tested for, let me know and I'll see what I can do. Video Review Below is a video review of the TM36. Due to my old image hosting site closing down, I've got new restrictions on image uploads and have replaced the "Construction" section of my reviews with a more detailed video review. For the TM36, I've done two separate videos: one standard review video, and one where I spend some time testing it's throwing capabilities.
Both of these videos are available in 1080p HD, but default to a lower quality. To select the playback quality click the settings button (looks like a gear) after you've started the video. Objective Manufacturer's Specifications Price: 500 USD ![]() Product Manual ![]() ![]() ![]() ![]() Dimensions ![]() Plus, here's a few shots with some good detail. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() User Interface Coming soon... Action Shots You can click on any of these shots to see them full size. Light in Hand ![]() ![]() ![]() ![]() MugShot ![]() BeamSlice ![]() White Wall ISO 100, f/3.5, 1/20" ![]() ![]() ![]() ![]() ![]() Indoor Shots ISO 100, f/3.5, 1" ![]() ![]() ![]() ![]() ![]() Outdoor Shots ISO 100, f/3.5, 2.5" ![]() ![]() ![]() ![]() ![]() Long-Range Shots ISO 100, f/3.5, 15" Control ![]() 150m ![]() 20x Zoom ![]() Control ![]() 230m ![]() 20x Zoom ![]() Control ![]() 500m ![]() 20x Zoom ![]() Performance Submersion: I submersed the TM36 under a foot of water for about an hour, clicking the switch several times. I found no evidence of water entering or damaging the light. Heat: PWM: Drop: I dropped the TM36 from about a meter onto various surfaces (including grass, carpet, dirt, and hard wood), and found no cosmetic or functional damage. Reverse Polarity Protection: Over-Discharge Protection: Spectral Analysis ![]() All light that we see as white is actually made up of several different colors put together. The relative intensities of the different colors in the mix are what determine the tint of the white we see. For example, cool white LED's have a lot of blue, and warm white LED's have more red or yellow. This measurement was done on a home made spectrometer. The plot below the picture is corrected for the spectral sensitivity of the human eye. Note: the peak in the 900nm region doesn't really exist, it's a piece of the second-order spectrum that's showing up here because of the high intensity of the light source. Output and Runtime ![]() ANSI FL-1 runtime ratings are the time it takes for a light to fall to 10% of it's original output (counting from 30 seconds after turning the light on). The vertical axis of the graphs below represents a relative brightness measurement using a home made light box. The horizontal axis is time in hours:minutes:seconds. Runtimes are stated in hours:minutes:seconds. These graphs may be truncated to show detail. Mode Comparison Turbo ![]() High ![]() Throwing Distance ANSI FL-1 standard for stating a light's throwing distance is the distance at which the peak beam intensity (usually at the center of the beam) is 0.25 lux. I calculate throwing distance and candela (lux at 1 meter) by measuring peak beam intensity at five different distances and using the formula lux*distance^2=constant. ![]() Note: A calibration factor of ~6.88% has been added into my throw measurements starting on 9.11.14. To compare the throw of a light I reviewed previous to that date, multiply the candela value by 1.0688 to get the corrected value. Subjective Review Quick break down: + - Coming soon... ![]() Long Term Impressions I'll fill this part in after carrying the light for a while. If nothing get's added here, either I find nothing else worth noting about the light, or I end up not using it often. |
Регистрация: 13.07.2014 Последняя активность: 28.09.2025 14:49
Сказал(а) спасибо: 666
Поблагодарили: 274 раз(а) в 163 сообщениях
Регистрация: 29.11.2012 Последняя активность: 05.01.2018 02:18
Сказал(а) спасибо: 280
