Просмотров в теме 2230   Ответов в теме 0   Подписчиков на тему 0   Добавили в закладки 0
Старый 05.09.2014, 10:25 Автор темы   1
Аватар для viperxp
Последняя активность: 26.07.2025 11:59
Сказал(а) спасибо: 144
Поблагодарили: 2408 раз(а) в 509 сообщениях
По умолчанию Olight M18 Striker review (800 lm, XM-L2, 18650/2xCR123A)
Greetings All.
This review obviously will be dedicated to a new flashlight from Olight, the
Olight M18 Striker.
What is it all about?
I will try to explain as simple as possible. There is the classic S20 Baton EDC flashlight. The flashlight has more "strategic" version - the M10 Maverick. The M18 Striker is actually more aggressive version of the Maverick. The aggressiveness is expressed obviously in the very distinctive design, 2 modes + strobe setup always starting at max setting and off course the evil stainless steel bezel.
The flashlight is controlled by one button at the tail (tactical forward clickie) , and the button is not covered in any way - so no tailstanding here.
Here we go
The package looks very nice, with the refreshed colors and logo of Olight. You can get all the flashlight technical specs from the package, and see the flashlight in all it's glory. Please note that the 800 lumens is the maximum brightness, and after 5 minutes the flashlight steps down to 480 lumens - and stays at this level till the batteries eventually die.
The package includes the flashlight itself, 2 spare o-rings and button cover, lanyard, user manual and some Olight commercials.
The flashlight feels very light and compact. The lens is clean, no fingerprints or dust there. The LED is perfectly centered. The reflector is relatively deep, maybe two times deeper than on the S20 Baton. The finish is perfect - no anodizing flaws or rough spots.
The flashlight is equipped with battery magazine for using CR123A batteries. In the head it has spring that will assist in absorbing an impact if the flashlight is dropped, and allows the use of flat top batteries.
The threads are square cut, anodised. Tailcap is very light and screwed in in about two rotations.
The flashlight always turned on on max setting. Double half click sets the flashlight in minimum setting, triple turns on strobe mode.
Some size comparison with other popular EDC flashlights. Left to right we have Baton S20,Convoy S3, Olight M18 Striker, Thrunite TN12 2014.
This is the shape of the beamshot on white wall, courtesy of the distinctive aggressive striking bezel shape.
Some numbers (lux in hotspot in meter from the flashlight)
Nothing exceptional here. The flashlight is completely silent, no PWN in any mode.
Conclusion
If you are looking for compact self-defence you might take the Olight to consideration. I could not find any serious flaw in it.
The flashlight was provided by Olight for review.
Olight Разные ZebraLight SC5W
viperxp вне форума   Ответить с цитированием Вверх
Время генерации страницы 0.09705 секунды с 16 запросами
