Вернуться   Форум FONAREVKA.RU Источники питания и зарядные устройства Batteries and Chargers. Reviews and tests. Battery chargers. Reviews and tests.
Просмотров в теме 2251   Ответов в теме 0   Подписчиков на тему 0   Добавили в закладки 0
Старый 05.09.2014, 10:13 Автор темы   1
Аватар для viperxp
Последняя активность: 26.07.2025 11:59
Сказал(а) спасибо: 144
По умолчанию Xtar MC0 Charger review
Greeting All, this review is dedicated to Xtar new mini charger, the MC0
These are the tech. specs as you can see. This is a mini charger, so forget about charging large batteries like 18650. The charger is very compact and so are the batteries that is supports (10440/14500/16340/17500/18350/18500 3.6/3.7V Li-ion batteries).
Pics, descriptions
The box is very small, you can easily recognize Xtar design.
There are not much bundled accessories inside. It is supposed to be more a budget charger than a premium one, so the less is better for keeping the price low. All the necessary stuff is there.
The charger cannot be easily disassembled, I believe it is glued together. The build is very solid, if feels very rigid. There are tech. specs in a very tiny font on the back panel, and anti-piracy label on the side.
You can see the size of the charger in comparison with Trustfire protected 14500 battery - it is not much bigger than the battery itself. The red indicator tells that it is currently charging, it turns green when the charging is done and when there is no battery in. The blue indicator tells the chosen current - 0.25 or 0.5 amperes. The selection key is mechanical - when is is pressed - it's 0.5, when not the charging current is set to 0.25A.
Here you can see the size of the charger compared with Xtar VP1 and Memorex PRO1 Geniux (Maha C9000 with different name). The charger is really tiny. The batteries and the charger stayed completely cool during the charging process.
I have charged several batteries, voltage was between 4.18 and 4.19 on all batteries.
HKJ did not find serious flaws with the charger as well.
Conclusion
Another good device from Xtar. If you are looking for a very compact charger, and the functionality of MC0 fits your needs, it may be the charger for you.
The charger was provided for review by Xtar.
Olight Разные ZebraLight SC5W
viperxp вне форума   Ответить с цитированием Вверх
Время генерации страницы 0.12295 секунды с 15 запросами
