Просмотров в теме 4831   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 02.09.2014, 18:37 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of Sony US18650VTC5 2600mAh (Green)
Official specifications:
  • Nominal Capacity (0.2C discharge): 2600mAh 9.36Wh (2.0V cut-off)
  • Rated Capacity (0.2C discharge): 2500mAh 9.00Wh (2.0V cut-off)
  • Capacity at 1C: 2563mAh 9.23Wh (2.5V cut-off)
  • Capacity at 10A: 2577mAh 8.80Wh (2.5V cut-off)
  • Nominal Voltage: 3.6V
  • Internal Impedance: 13.0mOhm Typ. measured by AC1kHz
  • Cycle Performance: 70% Min. of Initial capacity at 300 cycles 10A discharge, 2.5 volt cut-off
  • Size (with plastic tube): Diameter 18.35mm max, Length 65.20mm max
  • Standard Charge Current : 2.5A
  • Standard Charge Time : 2.5h
  • Weight: 44.3g Average
This is a very high current cell.
I do not test it fully, as can be seen in the specifications above it can be discharged down to 2.0 volt, but it looks like 2.5 volt is the preferred value.
The label is not from Sony but applied by Akkuteile.de
Very impressive tracking between the cells, it is difficult to see that there is curves for two cells.
According to the datasheet for the cell the temperature can raise more than 50°C during a 20A discharge.
Conclusion
This is a very good high current battery, it has fairly high capacity and can deliver a lot of current.
Notes and links
The batteries was supplied by Akkuteile.de for review.
stranix (02.09.2014), Сумской (02.09.2014)
Время генерации страницы 0.09486 секунды с 15 запросами
