Вернуться   Форум FONAREVKA.RU Торговая площадка Групповые покупки товара
Просмотров в теме 19838   Ответов в теме 48   Подписчиков на тему 13   Добавили в закладки 2
Старый 22.08.2014, 14:42 Автор темы   1
Последняя активность: 07.03.2015 01:28
По умолчанию [GroupBuy] [BLF] Opus BT-C3100 2.1 Новая версия $45
Закупка обновленной зарядки на BLF
ветка на BLF:
http://budgetlightforum.com...
То что обновлено
The improvements of the 2.1 version provided by Henry Xu, the engineer of this dream charger:
1. voltage update rate is 30s instead of 60s.
2. charging voltage is regulated to 4.7v instead of 5.0v, thus loading on power adapter when batteries are flat is less. 5.0v charging voltage has problem in regulating the correct current level due to this over loading current on power adapter, which lead to Panasonic brand Li-ion batteries showed wrong charging capacity value(+25%). With 4.7v charging voltage, the load on power adapter is greatly reduced and thus can make all types of batteries are charged properly.
3. 4.35v charging time can be very long because charging current is regulated in entering the CV stage at 4.12v, which is same as 4.2v type. Now 4.35v charging algorithm is changed to 4.27v.
4. Better safety feature: PCB temperature was used to in controling fan on/off only with 2.0v, now this function is enhenced so that temperature is monitored for entering thermal shutdown mode when excessive high temperautre is reached. It is especially helpful when fan is not running and which can lead to plastic melt down happening.
5. new fan cover make better protection for cooling fan.
Zerg32 вне форума   Ответить с цитированием Вверх
yurezz (22.08.2014)
Старый 22.08.2014, 16:01   2
yurezz
Огурец
Аватар для yurezz
Последняя активность: Сегодня 09:21
Сказал(а) спасибо: 1552
Поблагодарили: 537 раз(а) в 321 сообщениях
По умолчанию Re: [GroupBuy] [BLF] Opus BT-C3100 2.1 Новая версия $45
Barring any unforeseen circumstances, the 2.1 version will be shipped starting Aug. 27
если не возникнет непредвиденных обстоятельств, версия 2.1 будет отправлена начиная 27 Августа
заказал, будем подождать.
yurezz на форуме   Ответить с цитированием Вверх
+Alexp (26.08.2014)
Старый 26.08.2014, 01:26   3
+Alexp
Аватар для +Alexp
Последняя активность: 20.11.2025 22:25
Сказал(а) спасибо: 137
Посмотреть сообщение Сообщение от Zerg32 :
ветка на BLF:
То что обновлено
А можно ли всё это расписать по нашему и чтобы было понятно людям почему сделали версию 2,1
+Alexp вне форума   Ответить с цитированием Вверх
Старый 26.08.2014, 03:03   4
KAR2009
Последняя активность: 30.11.2025 02:31
Сказал(а) спасибо: 204
Поблагодарили: 561 раз(а) в 310 сообщениях
Посмотреть сообщение Сообщение от +Alexp :
Я своими словами переведу, без Гугле:
1. Изменена периодичность изменения индикации напряжения. Теперь 30 секунд. Ранее было 1 раз за 60 сек.
2. Изменено напряжение заряда аккумуляторы с 5.0 Вольт до 4.7 Вольта. Это сделано для уменьшения пиковой нагрузки на блок питания. Так у HKJ была проблема с показаниями количества заряда (+25%) во время заряда 4-х 18650. Уменьшение амплитуды импульсов заряда до 4,7В решило проблему Panasonic Li-ion батареями. В целом снижение импульсов тока благотворно влияет и на сетевой адаптер.
3. При включении 4,35 вольта режима заряда (переключатель внутри устройства). Ранее на напряжении 4,12 Вольт включался алгоритм заряда постоянным напряжением (СV), а не током. Это приводило к очень долгой зарядки таких аккумуляторов. В новой версии алгоритм CV включается на напряжении 4.27 Вольта, до этого порога зарядка идет постоянным током (СС).
4. Лучшая безопасность - контроль температуры платы осуществлялся в версии 2.0 путем включения-выключения вентилятора. В новой версии эта функция расширена и обеспечивает отключение устройства при достижении высоких температур функция режима отключения. Это функция особенно полезна, если вентилятор по каким-либо причинам не работает. В этом случае в версии 2.0 могло быть расплавление пластмассы корпуса. (От себя скажу, что я эксплуатировал 1-ю версию более недели без вентилятора и в ней четко работала защита по перегреву. Как я знаю, 2.0 версию без вентилятора производитель запрещает использовать.)
5. Новый вентилятор с лучшей защитой от повреждений. (Что это на практике означает пока не понятно.)
Вот и всё. Если они поставили более-менее нормальный вентилятор, то цена в 45 долларов оправдана, в остальном изменения минимальны и существенны для тех, кто планирует использовать BT-C3100 для заряда лития до 4,35 В.
[Исправлено: KAR2009, 26.08.2014 в 03:09]
KAR2009 вне форума   Ответить с цитированием Вверх
+Alexp (26.08.2014)
Старый 26.08.2014, 17:05   5
+Alexp
Аватар для +Alexp
Да, я уже писал, что пока не укажут или не скажет кто-то что за вентилятор там поставили... я пока лично воздержусь от покупки...
Старый 27.08.2014, 03:46   6
KAR2009
Я воздержусь от покупки (имею 1-ю версию и 2 зарядки версии 2.0) до той версии пока не введут к уже имеющимся функциям аналог режимов LaCrosse: "Refresh" (до 15 циклов разряд-заряд или пока не перестанет расти емкость) и "Disharge", назвав "Disharge Quick" (разряд и сразу заряд). При этом имеющиеся режимы "Disharge Refresh" (3 цикла разряд-заряд) и "Discharge" (разряд) следует оставить без изменений. Не вижу проблем для реализации этого пожелания. И конечно, пока не будет нормального качественного тихого вентилятора с защитной решеткой.
[Исправлено: KAR2009, 27.08.2014 в 04:15]
Старый 27.08.2014, 18:07   7
stranix
Аватар для stranix
Последняя активность: 07.03.2025 16:43
Сказал(а) спасибо: 107
Поблагодарили: 57 раз(а) в 51 сообщениях
KAR2009
Так действительно "discharge" только высаживает и более ничего? Т.е. это не аналог режима в лакросс для предотвращения эффекта памяти - т.е. разряд-заряд?
Вообще, честно говоря, логика производителя не совсем ясна, кому могут понадобиться разряженные акб и для чего?
stranix вне форума   Ответить с цитированием Вверх
Старый 28.08.2014, 09:43   8
KAR2009
Посмотреть сообщение Сообщение от stranix :
KAR2009
Да, "discharge" это только разряд. Приходиться для предотвращения эффекта памяти делать 2 операции - "разряд" и потом снова программировать на "заряд". Лишняя ручная работа и потеря времени. В принципе, функция разряда без заряда весьма полезна для оценки остаточного заряда в аккумуляторе, но нужен и еще один "разряд" как в LaCrosse.
Старый 28.08.2014, 11:03   9
KAR2009
Лучше было прочитать то, что писал главный инженер Опус Генри Сюй (Henry Xu ) месяц назад. В спойлере оригинальный текст, а ниже перевод частично исправленного Гугле с мелкими моими дополнениями курсивом:
I know some customer purchased earlier before June won’t feel comfortable when seeing this message. I am really sorry. But I do hope your understanding that we did at our best when releasing V2.0 earlier this year.
I re-write the improvement points below and our next product step in below. Thanks for all the input and we appreciate!
+*oncerning the feedback with V2.0 BT-C3100, we are going to release a new version in August: V2.1
The changing contents are:
1. voltage refresh update rate is changed to 30s, instead of 60s.
2. charging NCR18650B or NCR18650PF type Panasonic battery mAH data is optimized by controlling charging current level( regulate li-ion charging voltage from 5.0v to 4.65v, and its peak charging current needed will be less now), and mAH data will be correct, with our supplied power adapter used( still need to meet minimum output current to be over 3A@12v). This problem has been improved with v2.0 in the later shipments to Gear Best in June already.
3. temperature sensing for controller board now not only turns on/off cooling fan(v2.Innocent, but also accurate controller board temperature monitored so that over heating condition will be sensed as well. This is better safety feature when fan is not running and overheating on controller board will trigger over heat charging/discharging protection to be kicked in. We don’t recommend any operation of this charger without fan operation with v2.0 charger, especially during discharging time with li-ion batteries.
4. improved accuracy of charging and discharging current measurement to be within +/- 3% accuracy now, while v2.0 version has 5% current regulation accuracy. This is realized through hardware change. Improved battery voltage accuracy via hardware design change.
5. when reversed polarity batteries installed on charger, with v2.0 charger, there can have high pulse charging current existed due to pre-charging feature activated( charger detects reversed battery as 0v voltage, and treated the battery as complete flat ones, so pre-charging on flat batteries are activated and this can cause high pulse current). With v2.1 design, this pre-charging pulse is cancelled to avoid high pulse current during the time of reverse battery polarity being connected on charger.
6. Battery self discharge and charger related leakage will lead to batteries voltage keep dropping after fully charged. Auto recharging procedure will activate when battery voltage dropped beyond 4.12v.
7.Improved charging termination for ni-mh batteries. Much less heat generated during last charging phase period.
8. For 4.35 and 3.7 batteries, charging CV stage starts at 4.26 and 2.8v respectively. This is helpful in reducing the charging time needed for fully charged
With the above changes done, we think this charger needs no more firmware update anymore.
Since the controller on board is One Programmable Only type, so we can’t support on line firmware grade option. And I am really sorry for this.
The XStar charger used pure DC current charging design , while our BT-C3100 uses averaged PWM CC charging algorithm. There are still debates going on with the two different charging method for nimh batteries. Some researches say that PWM type averaged CC is better for nimh or nicd batteries. However during our own research, we do find pure DC CC charging has one obvious advantage: There is no extreme high power pulse built during charging phase, while our BT-C3100 suffered this problem. This high current exists mainly when completely empty batteries are charged. When battery voltage is over 3.6v, the current is not that high at all. The panasonic li-ion battery stores much more energy at the voltage range of 2.8v ~3.7v ( about 1000mah), while samsung li-ion battery stores only 100mah at this voltage range. So extrem high current charging time needed for panasonic batteries are much longer and its charging current is much higher. We cornered around this problem by controlling the DC/DC bulk converter output voltage from 5v to 4.65v. This brings the benefits of having less high current needed, and thus have the charging capacity data improved.
As HKJ mentioned, this problem can be improved by shifting the phase of 4 charging channels, and split the high current evenly. But the controller resources is not allowing us to do so. We are working on a pure DC current charging circuit now, and I hope we can have a new model out sometime in 2015.
HKJ: Can I send our improved V2.1 for your further testing? +*
Пн, 07/21/2014 - 2:59
# 1337
Генри Сюй Henry Xu's
Я знаю, что некоторые клиенты купившее ранее (BT-C3100 V2.0) до июня, не будут чувствовать себя комфортно, когда увидите это сообщение. Мне очень жаль. Но я надеюсь на ваше понимание, что мы делали всё, что в наших силах выпустив V2.0 ранее в этом году.
Я решил показать ниже (по тексту) какие улучшения сделаны в следующей версии продукта. Спасибо всем и мы ценим (вашу поддержку и терпение)!
Мы собираемся выпустить новую версию V2.1 в августе:
Изменения:
1. Частота (правильнее период) обновления измерения напряжения изменяется на 30 секунд, вместо 60 с.
2. При зарядке Panasonic NCR18650B или NCR18650PF данные по значению мА*ч показывают верное текущее значение за счет оптимизации управления текущим уровнем заряда (при заряде Li-Ion амплитуда (максимум) зарядного напряжения изменен с 5,0 В до 4.65v, что позволило уменьшить пиковое потребление зарядного тока). В результате, данные по значению мА*ч будут правильные, с использованием наше комплект адаптера (блока питания) (ещё было необходимо уменьшить ток, чтобы не быть более 3А @ 12v). Эта проблема была частично решена в версии v2.0 более поздних поставок магазина gearbest.com уже в июне (2014 г.).
3. (Алгоритм) измерения температуры для платы контроллера теперь не только включает-выключает вентилятор охлаждения, но и следит за точной температурой платы контроллера и за (оптимальным) нагревом. Это улучшает функцию безопасности, когда вентилятор не работает и имеет место перегрев на плате контроллера, вызванный более высокой температурой зарядки-разрядки. Мы не рекомендуем любую работу данного зарядного устройства версии 2.0 без работы вентилятора, особенно во время разряда литий-ионных батарей.
4. Улучшена точность измерения тока при зарядке и разрядке в пределах +/- 3%, в то время как версия v2.0 имеет 5% погрешность регулирования тока. Это реализована путем изменения аппаратной части. Также повышена точность измерения напряжение батареи путем изменения аппаратного дизайна.
5. Когда (ошибочно установлен аккумулятор так, что имеется) обратная полярность батареи, то установленные в зарядное устройство v2.0, могли иметь высокий импульс тока зарядки, за счет активной функции предварительной зарядки (зарядное устройство версии 2.0 определяло перевернутые батареи в качестве 0 Вольт напряжения и обрабатывают как батарею с активацией функции предварительной зарядки, что может привести к высокому импульсному току). С дизайном v2.1, это предварительный зарядный импульс отменен, чтобы избежать высокого импульсного тока во время обратной полярности батареи, подключаемого на зарядное устройство.
6.После полной зарядки имеется разряд через зарядное устройство и саморазряд аккумуляторов, что приводит падению напряжения на аккумуляторе. Процедура автоматической подзарядки активизируется (для лития), когда напряжение снизится менее чем 4.12v.
7. Улучшена зарядка Ni-MH аккумуляторов. Гораздо меньше нагрев, чем прошлые версии зарядки.
8. Для 4,35В и 3,7В батарей, зарядки CV этап начинается в 4.26В и 2,8В соответственно. Это полезно для сокращении времени полной зарядки.
С учетом сделанных вышеназванных изменений, мы думаем, что это устройство больше не нуждается больше в обновление прошивки.
Так как установлен контроллер в BT-C3100 не поддерживающий перепрограммирование, то мы не можем поддерживать обновление прошивки. И я очень извиняюсь за это.
Зарядное устройство Xstar используется чистый постоянного тока дизайн зарядки, в то время как наша BT-C3100 использует в среднем ШИМ CC зарядки алгоритм. Есть еще дебаты происходит с двух разных способа зарядки для никель-металлогидридных батарей. Некоторые исследования говорят, что типа PWM среднем CC лучше для никель-металлогидридных или никель-кадмиевых аккумуляторов. Однако в ходе нашего собственного исследования, мы находим чистый DC CC зарядку имеет один очевидный плюс: Там нет крайняя импульсов высокой мощности построен во фазу зарядки, в то время как наша BT-C3100 пострадали эту проблему. Это большой ток существует в основном, когда полностью разряженные батареи взимается. Когда напряжение батареи составляет более 3,6, ток не что высокий вообще. В Panasonic магазины Аккумулятор Li-Ion гораздо больше энергии в диапазоне напряжений 2,8 В ~ 3,7 В (около 1000mAh), в то время как Samsung сохраняет литий-ионный аккумулятор 100mAh только в этом диапазоне напряжений. Так экстремального высокого текущее время зарядки необходимо для Panasonic батареи гораздо дольше и его зарядный ток намного выше. Мы загнаны в угол вокруг этой проблемы, контролируя основная Выходное напряжение преобразователя DC / DC с 5 до 4.65v. Это приносит преимущества наличия необходимой меньше высокий ток, и, таким образом, есть данные на емкость улучшилось.
Как уже упоминалось HKJ, эта проблема может быть улучшена путем сдвига фазы 4 Зарядка каналов, и разделить большой ток равномерно. Но контроллер ресурсов не позволяет нам сделать это. Мы работаем на чистом зарядной цепи постоянного тока, и я надеюсь, что мы можем иметь новую модель из когда-то в 2015 году.
HKJ: Могу ли я отправить нашу улучшенную V2.1 для дальнейшего тестирования? + *
Генри Сюй написал:
К сожалению, я забыл упомянуть это: 4.35 В заряд быстрее. V2.0 режим CV включался на 4.12 В даже с выбранным режимом 4,35 В. Теперь переключение на 4.25 В для CV фазы.
[Исправлено: KAR2009, 28.08.2014 в 11:15]
+Alexp (22.09.2014), abcom (26.03.2015), Puma (23.09.2014), stranix (28.08.2014)
Старый 22.09.2014, 19:12   10
+Alexp
Аватар для +Alexp
Почитал. Перечитал. Заказал V2.1.
Старый 28.09.2014, 21:10   11
Gomola Ivan
Последняя активность: 20.03.2017 07:34
Я себе тоже заказал! Уже в Мск сортировочный покиныла посылочка! Жду с нетерпением!
Gomola Ivan вне форума   Ответить с цитированием Вверх
Старый 28.09.2014, 21:48   12
Agstroy
Последняя активность: 03.03.2025 09:41
Сказал(а) спасибо: 153
Тоже присоединюсь к покупке девайса.
Agstroy вне форума   Ответить с цитированием Вверх
Старый 04.10.2014, 00:32   13
+Alexp
Аватар для +Alexp
Плохо ходит.
Трек дали от 18-09-2014
Ничего до сих пор не трекается.
Старый 04.10.2014, 10:36   14
gearbest.com
Gearbest- Леда
Аватар для gearbest.com
Последняя активность: 16.05.2020 01:38
Сказал(а) спасибо: 493
Поблагодарили: 1633 раз(а) в 1137 сообщениях
сейчас с новым купоном OP3100SQ, скидочная цена будет 42долларов. Если кто то ещё хочет сделать заказ, можно пользовать этот купон.
gearbest.com вне форума   Ответить с цитированием Вверх
Старый 04.10.2014, 18:21   15
+Alexp
Аватар для +Alexp
gearbest.com, W1408251422433603 вы сказали, что 18-09-2014 ушло. А можно уточнить, куда оно ушло? track не отслеживается.
Старый 05.10.2014, 02:18   16
stranix
Аватар для stranix
Наверное, тоже HongKong Post Unregistered? Как у меня и тут:
Старый 05.10.2014, 08:19   17
Shandor_Kalosh
Последняя активность: 04.04.2019 06:19
Сказал(а) спасибо: 77
Поблагодарили: 55 раз(а) в 35 сообщениях
Посмотреть сообщение Сообщение от gearbest.com :
Уже интересная цена. Надо подумать над приобретением 2.1v. В плане поломки вентилятора уже не стоит беспокоиться?
Shandor_Kalosh вне форума   Ответить с цитированием Вверх
Старый 05.10.2014, 21:11   18
Gomola Ivan
А с предыдущим купоном она такая и была!
Я кстати свою зарядку уже дождался
Старый 05.10.2014, 23:08   19
+Alexp
Аватар для +Alexp
У меня посылка трекнула. Ниделранды...
Старый 06.10.2014, 09:17   20
Gomola Ivan
У меня зарядка тоже пришла из Нидерландов не пугайся!
Время генерации страницы 0.17176 секунды с 15 запросами
