Просмотров в теме 2155   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 17.08.2014, 19:35 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of Windyfire IMR18350 850mAh (Red)
Official specifications:
  • Type of Battery: IMR 18350/850mAh
  • Size(mm): 18mm(Diameter) x 35mm(Length)
  • Positive Shape: Button top
  • Weight(g): 22±1g
  • Nominal Voltage: 3.7V
  • Nominal Capacity: 880mah(0.2 C Discharge)
  • Minimum Capacity: 850mah(0.2 C Discharge)
  • Discharge Cut-off voltage: 3 V
  • Standard Charge: 0.4 A /4.2V
  • Maximum charge current: 0.85A
  • Quick Discharge Current: 0.85 A
  • Max Discharge Current: 4 A
  • Initial Impedance : Max:65mOhm
  • Cycle Life: 310times: discharging capacity>85%, 510times: discharging capacity>60%
  • Temperature Characteristics: -10°C/0.2C >80% Capacity; 20°C/0.2C =100% Capacity;60°C/0.2C >95% Capacity
  • Charging Time: Standard charge : 5-7hours, Rapid charge : 2-3hours
  • Operating environment: Charging, 0°C ~ 45°C ; 65±20%RH, Discharging, -20°C~60°C ; 65±20%RH
  • Storage environment: Temp(-20°c -35°c) / Relative humidity (45-75%)
This is a IMR cell, but only with moderate high current ability, but good capacity.
The cell does fine up to 3A load, but at 5A load it loses significant capacity.
Conclusion
These batteries has good performance at moderate loads and I will rate them acceptable.
Notes and links
The batteries was supplied by Windyfire for review.
Comparison to other LiIon batteries
[Исправлено: HKJ, 17.08.2014 в 19:39]
Время генерации страницы 0.07943 секунды с 15 запросами
