Просмотров в теме 2238   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 04.07.2014, 20:09 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of Xtar 18650 2100mAh (Black)
Official specifications:
  • Typical capacity: 2100mAh
  • Minimum capacity: 2000mAh
  • Nominal voltage: 3,6V-3,7V
  • Charge voltage: 4,2V ± 0,05V
  • Discharge voltage: 2,5V
  • Max. charge current: 4A
  • Max. discharge current: 15C = 30A
  • Chemical composition: LiNiMnCoO2
  • Protection circuit (BMS): No
  • Positive pole: button top
  • Diameter: 18,4mm ± 0,2mm
  • Height: 67,0mm ± 0,5mm
  • Weight: 46g ± 0,01g
  • Charging method: CC-CV
This is a high current 18650 battery from Xtar.
The two cells tracks very nicely and has nearly constant capacity up to 15A, but they are not really suited for 30A continuous draw.
Conclusion
The batteries is a good battery with acceptable performance, but the 30A specification is a bit misleading.
Notes and links
The batteries was supplied by Akkuteile.de for review.
Время генерации страницы 0.08068 секунды с 15 запросами
