Вернуться   Форум FONAREVKA.RU Источники питания и зарядные устройства Batteries and Chargers. Reviews and tests. Battery chargers. Reviews and tests.
Просмотров в теме 23465   Ответов в теме 44   Подписчиков на тему 9   Добавили в закладки 0
Старый 28.06.2014, 20:27 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of Ikea Ladda YH-990BF
Ikea Ladda YH-990BF
Ikea does not only sell furniture, but does also have some other stuff. With some help from Sweden I got this charger to test.
The charger is packed in blister pack with the charger on one side and the mains cable on the other side.
There box contains the charger, mains cable and a manual in 26 languages.
The charger has build in power supply and is universal voltage (100-240VAC 50/60Hz).
There is no buttons on the charger, only a single indicator. It is red when any of the four channels is charging and changes to green when all channels are idle.
I.e. it is not possible to know if one battery is finished, only if all batteries are finished.
The charger uses a two-step connection for AA and AAA batteries and will automatically change charge current depending on battery size.
Measurements
  • Discharge battery with less than 0.1mA when power is disconnected.
  • Charge battery with about 12mA in trickle current, when charging is done.
  • Charge will restart charging after power loss or battery insertion.
  • The led is common for all four batteries and will first turn green when all are charged.
  • It takes about 10 minutes to detect a full battery.
The charger uses a 1A charge current and a -dv/dt termination. When charging only one battery the charger is fairly cool, except when terminating (Exactly as expected).
There is not much difference between the four channels.
The eneloop XX takes a bit more time to charge.
With AAA batteries the current is reduced to 0.5A for the last part of the carge, as can be seen on the curves below this is done with pwm.
The charger uses -dv/dt to detect a full battery, this means it takes about 10 minutes to detect if charging is tried on a full battery.
With four batteries the charger gets fairly warm.
M1: 51,4°C, M2: 43,4°C, M3: 47,2°C, M4: 46,7°C, M5: 43,3°C, HS1: 58,3°C
The charger is fairly fast to start when powered up.
During charge it turns the current off each other second to check the voltage.
With AAA cells it uses pwm to half the charge current.
The trickle is pulses, but at a fairly low current and the average trickle charge is also at a fairly low level with 12 mA.
Testing the mains transformer with 2500 volt and 5000 volt between mains and low volt side, did not show any safety problems.
Conclusion
The charger does a good job of charging NiMH batteries with correct -dv/dt algorithm and has a nice low trickle current.
I would have liked it cooler, but that is very difficult to do with a small charger than can charge four batteries at 1A. I would also very much have liked to have a indicator for each channel, not only a common indicator.
I will call this a simple and good charger.
Notes
The charger was supplied by an open minded fan from Sweden for review.
Here is an explanation on how I did the above charge curves: How do I test a charger
Admin (30.06.2014)
Старый 28.06.2014, 22:21   2
SERG27
Сказал(а) спасибо: 1914
По умолчанию Re: Test/Review of Ikea Ladda YH-990BF
тупо в дополнение- там и акки есть, грят неплохие...
http://fotograffo.ru/palchi...
Leschka (29.06.2014)
Старый 28.06.2014, 22:46   3
Joss99
Последняя активность: 04.04.2017 16:31
Сказал(а) спасибо: 52
Про батарейки скажу, что это лучший вариант цена качество. Дома давно уже только они. Акки пока не пробовал, пора затестить.
Joss99 вне форума   Ответить с цитированием Вверх
Старый 29.06.2014, 15:56   4
Посмотреть сообщение Сообщение от Joss99 :
Не текут?
Старый 29.06.2014, 17:15   5
Leschka
Последняя активность: 15.10.2025 23:18
Сказал(а) спасибо: 21
Посмотреть сообщение Сообщение от SERG27 :
Я теперь в замешательстве,хотел заказать Энелупы но на страничке Икеи эти Ладды 199р за 4 штучки) Смысл платить больше?
Leschka вне форума   Ответить с цитированием Вверх
Старый 29.06.2014, 18:40   6
uV3
Сказал(а) спасибо: 249
Посмотреть сообщение Сообщение от Leschka :
eneloop берите.
Старый 29.06.2014, 19:25   7
Скупой платит дважды... Не слушайте агитацию от любителя 3баксовых зумов для всех задач.
Старый 29.06.2014, 19:34   8
lem nau
Последняя активность: 06.05.2025 15:53
Сказал(а) спасибо: 474
Поблагодарили: 614 раз(а) в 310 сообщениях
Wink2 Re: Test/Review of Ikea Ladda YH-990BF
Оппа. Ikea уже и на рынке зарядок отметилась :-o
lem nau вне форума   Ответить с цитированием Вверх
Старый 29.06.2014, 20:04   9
Joss99
Не текут?
Неа, всё супер.
Старый 29.06.2014, 20:26   10
SERG27
не променяй мозги на кошелек. здесь полфорума без шура поср.ть не выйдут-потому что не "КРУТО"... тебе шашечки или ехать? у всех мажоров зумы были, у многих остались. но они скорее повесятся, чем признаются в этом. когда аргументы и факты кончаются давят числом и авторитетом. не получается- банят. так, что думай сам.
Старый 29.06.2014, 20:37   11
SERG27
Посмотреть сообщение Сообщение от uV3 :
eneloop берите.
вы статью внимательно читали? слили ваши энелупы. так же как и у меня в тестах... но вы ни когда это не признаете... наверно ту статью тоже я написал? как же можно замахнутся на "богов"?... существует два мнения: МОЁ и неправильное, да? а факты- побоку- НЕВЕРЮ! И ВСЕ. ТОЧКА.
Старый 29.06.2014, 21:13   12
uV3
Голоса в голове?
Magvay (29.06.2014)
Старый 29.06.2014, 23:41   13
слили ваши энелупы.
Где тесты от авторитетного датчанина сравнительные?
SERG27 (30.06.2014)
Старый 30.06.2014, 19:22   14
+Alexp
Аватар для +Alexp
Последняя активность: 20.11.2025 22:25
Сказал(а) спасибо: 137
Ladda замечательные аккумуляторы на 100-120 циклов работы и столько же зарядок. И цена у них малая.
Можно тут почитать.
И решить для себя.
+Alexp вне форума   Ответить с цитированием Вверх
Старый 30.06.2014, 21:54   15
Аватар
Последняя активность: 28.06.2025 13:54
Сказал(а) спасибо: 26
Енелупы 125р за шт. эти я так понял 60? мои космос которыми всегда пользовался 100 р за шт. значит стоит брать? Дешего и сердито?
Аватар вне форума   Ответить с цитированием Вверх
Старый 29.10.2014, 00:33   16
gostuv
Аватар для gostuv
Последняя активность: 23.09.2020 20:16
Сказал(а) спасибо: 183
Поблагодарили: 49 раз(а) в 38 сообщениях
Sigh Re: Test/Review of Ikea Ladda YH-990BF
Иеех почитать бы все это вовремя и пойти в ИКЕА и закупиться зарядкой и акумами не мороча себе голову! Кучу денег и нервов бы сэкономил...
Достало ждать 6 часов пока зарядится фирмовой энелуповской(400 руб а икеевская 600 на 4 канала) зарядкой 2 АА батарейки.
Да и ничего такого особенного в самих энелупах за 5 циклов не заметил...
Учитывая ту же технологию (пусть при каком то проигрыше) икеевские отбили бы свою цену скорее и затрато-эффективнее....
Lumintop SD10 отработал 2 месяца и кончился>заменен на>Lumintop BLF SD10 , Fenix hl50, Lumintop worm 3, Hugsby h12080, Skilhunt H02R>заменен на>Skilhunt H03, Yupard-налобник
[Исправлено: gostuv, 29.10.2014 в 01:02]
gostuv вне форума   Ответить с цитированием Вверх
Старый 29.10.2014, 01:09   17
Vyacheslav Demeshko
Аватар для Vyacheslav Demeshko
Последняя активность: 20.05.2022 19:12
Сказал(а) спасибо: 211
gostuv, кто заставлял брать фирменную зарядку Eneloop на 2 канала? 4-х канальная MQR06 заряжает за 2 часа два белых Eneloop... и чуть больше часа 1 Eneloop
Zebralight: H600Fw MKII, H51c; Fenix: HL21, HL23, LD12 S2, E05 R2; Princeton Tec: Remix; Byte; Convoy: S2 T5-5C; Spark: SG5 CW; Xtar: WK41 Sirius AA; Petzl: Tikka 2, Tikkina 2; Olight: H1 Nova NW
Vyacheslav Demeshko вне форума   Ответить с цитированием Вверх
Старый 29.10.2014, 01:13   18
Vyacheslav Demeshko
Вы так и не выложили тесты что там после 100 циклов полного заряда.. после 200 циклов... что там после 1 года хранения на полки от остаточного заряда... и правильно.. мы бы смеялись и держались за живот от хохота
Старый 29.10.2014, 08:32   19
gostuv
Аватар для gostuv
Посмотреть сообщение Сообщение от Vyacheslav Demeshko :
1000 руб это другие деньги. За эти деньги уже в сторону ля кросса можно начинать смотреть
Старый 29.10.2014, 10:27   20
Vyacheslav Demeshko
Посмотреть сообщение Сообщение от gostuv :
который на малых токах зарядки плохо ловит дельту, а на больших довольно сильно греет аккумуляторы.. да и лукавите Вы так как за 1000 рэ там вряд ли будут 4 аккумулятора Eneloop в комплекте с зарядкой, как в случае с Sanyo MQR06
[Исправлено: Vyacheslav Demeshko, 29.10.2014 в 10:29]
Время генерации страницы 0.16088 секунды с 16 запросами
