Просмотров в теме 2229   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 26.06.2014, 21:54 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of Keeppower IMR18650 2600mAh (Black) 2014
Official specifications:
  • KeepPower IMR18650 3.6V/3.7V 2600mAh High Drain Li-ion Rechargeable Battery
  • Min Capacity: 2500mAh
  • Typical Capacity: 2600mAh
  • Normal Voltage: 3.6V/3.7V
  • Quality Lithium Ion rechargeable cell made in Japan
  • Maximum Capacity and Reliability
  • Maximum Constant Discharge Current: 40A
  • Maximum Pulse Discharge Current: 60A
  • 4.2 volts max voltage and 3.6-3.7 volts nominal voltage
  • Button top: Yes
  • Cell: Made in Japan
  • Dimension: Max. (D) 18.40mm*(H) 65.60mm
  • Weight: Max. 48.0g
This is a high current battery, how high varies with where I look. With the battery I got a note saying 30A, as can be seen above Keeppower gives it a higher rating on their website. I did also find a datasheet with discharge curves up to 20A.
Very good tracking between the cells. Looking at these curves I would prefer to stay at 20A or below in current.
Conclusion
This is a very good high current battery, it has fairly high capacity and can deliver a lot of current.
Notes and links
The battery was supplied by Keeppower for review
Admin (26.06.2014), Garrik (26.06.2014), WallE (26.06.2014), Сумской (27.06.2014)
Время генерации страницы 0.08423 секунды с 15 запросами
