Вернуться   Форум FONAREVKA.RU Обзоры фонарей Flashlight Reviews Headlamps. Flashlight Reviews.
Просмотров в теме 3595   Ответов в теме 0   Подписчиков на тему 0   Добавили в закладки 0
Старый 20.04.2014, 15:28 Автор темы   1
Аватар для gopajti
Последняя активность: 29.09.2015 22:48
Поблагодарили: 85 раз(а) в 24 сообщениях
По умолчанию **Pictures** Sunwayman C20C (XM-L U2) 450 lumens EDC flashlight
An excellent quality flashlight, the Sunwayman C20C Tomahawk
Features
● CREE XM-L U2 LED, with a lifetime of up to 50,000 hours;
● Soft-contact Side Switch:
One Turbo mode, three modes constant output, hidden Strobe and SOS (below are output and runtime details by using one 2600mAh 18650 battery)
Turbo Mode: 450 Lumens (for safety’s sake, after 5 minutes’ turbo mode, the light will go to High mode automatically to avoid over-heat)
Three constant output modes: 280Lumens (3hrs)95Lumens (10hrs) - 15Lumens (50hrs)
Strobe: 450Lumens
SOS
● Constant current circuit, constant output
Effective range of 139 meters
● Uses two 3V CR123A batteries or one single 18650 battery
● Working voltage: 4~8.4V
● High quality OP metal reflector maintains great throw distance and spread with an ideal beam pattern
● Dimensions: 105mm (length) x 25mm (head diameter) x 24mm (tail diameter)
● Weight: 57g (battery excluded)
● Aerospace-grade aluminum alloy, stainless steel retaining ring on the head
● Military Specification Type III- hard anodized body
● Waterproof, in accordance with IPX-8 standard
● Ultra-clear tempered glass lens resists scratches and impacts
● Tail stand capable- can be used as a candle
● Accessories: Clip, lanyard, holster, O-ring
voltage indicator first activity: 3.08V (measured by Cottonpickers nona charger)
more pictures (incl. beamshots) coming soon
all pics in 1024x768px
http://indafoto.hu/autoart/...
first beamshots (weather: rainy)
C20C (Panasonic NCR18650A) vs Spark SL6S-740NW (Samsung ICR18650-30A, 4.35V)
C20C (Panasonic NCR18650A) vs Sunwayman T20CS (Samsung ICR18650-30A, 4.35V)
gopajti вне форума   Ответить с цитированием Вверх
VovanV (11.01.2016)
Время генерации страницы 0.08430 секунды с 15 запросами
