Вернуться   Форум FONAREVKA.RU Обзоры фонарей Flashlight Reviews Headlamps. Flashlight Reviews.
Просмотров в теме 3755   Ответов в теме 0   Подписчиков на тему 0   Добавили в закладки 0
Старый 20.04.2014, 15:27 Автор темы   1
Аватар для gopajti
Последняя активность: 29.09.2015 22:48
Поблагодарили: 85 раз(а) в 24 сообщениях
По умолчанию **Pictures** Klarus XT30 (XM-L U2) 820 lumens thrower flashlight
Here is the newest Klarus light. First impressions:
+ excellent build quality (very similar than Jetbeam RRT series and Sunwayman lights)
+ excellent anodizing and color
+ smooth threads
+ high quality, clean, dust free reflector and lens
+ comfortable UI
+ nice, strong holster
- a little bit noisy driver
- slightly pwm flickering low and medium modes, but I can't see when I use in outdoor
Official site, user manual and box say: 10lm (180h), 310lm (5.5h), 820lm (1.8h) and 29000cd (max. 360m)
This light has more than 29000cd. It's sure.
I think, this is the correct specs,
Features:
  • Specially designed deep parabolic reflector produces a perfect beam profile and super long throw ability. Intended applications include Military, Law Enforcement, Hunting, Exploration, Security, Search & Rescue, etc
  • Uses a Cree XM-L U2 LED, which delivers a maximum output of 820 ANSI lumens
  • Max run time: 208 hours
  • Beam throw ability: 400 meters
  • New circuit design delivers both high lumen output and long runtime
  • Dual button tail switch for quick, one-hand operation. No need to fiddle with switches in two different places
  • Strobe can be activated with the Mode switch when the flashlight is on or off, giving instant access to Strobe from any mode
  • Detachable stainless steel strike bezel
  • Reverse polarity protection protects flashlight and battery from damage
  • Maintains constant brightness with super high efficiency
Specification:
  • CREE XM-L (U2) LED with a lifespan of up to 50,000 hours
  • Three lighting modes and 1 flashing mode:
    • Lighting modes: 820 ANSI lumens (2 hrs) --- 150 lumens (13.4 hrs) --- 10 lumens (208 hrs)
    • Variable frequency strobe: 820 lumens (4 hrs)
  • Working Voltage: 7V - 14V
  • Battery: 4x CR123A / 2x 18650 (use of 16340 batteries is not recommended)
  • Body color: Military grey
  • Reflector: Deep smooth reflector
  • Tactical main switch for turning the light on and off. Momentary activation from off
  • Dedicated mode switch for instant access to strobe and changing modes
  • Lens: Toughened ultra-clear glass
  • Material: Aircraft grade aluminum 6061-T6
  • Dimensions: 248.1mm (Length) x 58mm (Head) x 25.4mm (Body)
  • Net weight: 273g (Excluding battery)
  • Waterproof to IPX-8 Standard (underwater to 2 meters)
  • Included accessories: Holster, lanyard, metal tactical ring and two spare o-rings
Note: The above-mentioned parameters are approximate and may vary between flashlights,
batteries and environments. Data was achieved using SANYO 18650 2600 mAh lithium ion
batteries.
Operation:
  • To activate constant-on, press tail/ higher switch fully so that it clicks. To turn the flashlight off, press tail switch fully so that it clicks.
  • Changing brightness levels: When the flashlight is on, press the Mode switch and then release it immediately; the brightness mode will change: High – Medium - Low.
  • Strobe access: With the flashlight turned off, press the Mode switch for instant access to strobe. With the flashlight turned on, press the Mode switch for more than 0.6 of a second to access strobe. Release Mode switch within 2 seconds to return to your previous lighting mode. Holding the Mode switch for more than 2 seconds will lock the light in strobe mode. Pressing the Mode switch will stop the strobe mode and return the light to its previous lighting mode.
  • Momentary activation: lightly press the main tail switch with no click.
and now, here is the pics
distance about 50m
XT30 vs Sunwayman T20CS
XT30 vs Fenix TK35 U2 (29000cd)
XT30 vs Olight SR51
gopajti вне форума   Ответить с цитированием Вверх
Время генерации страницы 0.08193 секунды с 15 запросами
