Просмотров в теме 1617   Ответов в теме 0   Подписчиков на тему 0   Добавили в закладки 0
Старый 20.04.2014, 15:21 Автор темы   1
Аватар для gopajti
Последняя активность: 29.09.2015 22:48
Поблагодарили: 85 раз(а) в 24 сообщениях
По умолчанию **Pictures** Rofis TR31C Rechargeable (XM-L U2, 655lm)
This light arrived few days ago, here is the first pictures,
Official site
http://www.rofislight.com/_...
Details,
- Cree XM-L LED (U2) with a lifespan of 50,000 hours
- Battery: 2x CR123A / 1x 18650 / 2x 16340 (16340 battery is not recommended)
- 152 mm (length) x 25.4 mm(body ) x 39.8mm(head diameter)
- 180-gram weight (excluding batteries)
- It can be charged in the car, on the computer and household electric supply device,etc
- Digitally regulated output - maintains constant brightness
- Intelligent memory circuit,automatically memorizes the brightness level when switch off
- Over-discharge protection function, when the battery is in low voltage, the light will flicker twice every two minutes
- Reverse polarity protection, to protect from improper battery installation
- Turbo mode will automatically decline to 500LM after 10 minutes,to protect the light from over-heating.
- Two modes and seven types of output
- Capable of standing up securely on a flat surface to serve as a candle
- stainless steel attack head
- Adopt double-switch design (tail tactical switch, side dimmer switch)
- Made of durable aircraft-grade aluminum
- Premium Type III hard-anodized anti-abrasive finish
- Toughened ultra-clear glass lens with anti-reflective coating
Notice: The above-mentioned parameters (tested in lab by using quality CR123A primary Lithium batteries) are approximate and may vary between flashlights, batteries, and environments.
We suggest you use protected 18650 battery when you charge the light, reverse battery installation is forbidden, the CR123A and 16340 battery are forbidden.
my impressions:
+ Very robust, thick body, excellent build quality
+ nice matte black anodizing
+ smooth, clean threads
+ nice white tint (only low mode slightly yellowish)
+ silent driver
+ all modes are ok (no pwm flickering etc)
+ perfect beam quality (no rings)
+ clean reflector, lens
+ nice SS bezel
+ hidden strobe, sos, frequent flashing
+ incl. strong, high quality holster
+ large batteries (eg. XTAR 18700) fit perfect. Unprotected cells no rattle.
Rofis says, the charger use CC/CV algorithm
pls click image for higher res
gopajti вне форума   Ответить с цитированием Вверх
Время генерации страницы 0.10827 секунды с 15 запросами
