Просмотров в теме 2331   Ответов в теме 0   Подписчиков на тему 0   Добавили в закладки 0
Старый 20.04.2014, 15:20 Автор темы   1
Аватар для gopajti
Последняя активность: 29.09.2015 22:48
Поблагодарили: 85 раз(а) в 24 сообщениях
По умолчанию ***Pictures*** Dereelight XSearcher (Aspheric thrower)
Long-range LED searchlight with focusable beam
The Dereelight XSearcher is one of the most powerful and lightweight handheld searchlights in the world. It uses small, high power lithium batteries to help you search further for longer. It's ideal for Police, Search & Rescue, hunting (as a spotting lamp) and any situation where you want to illuminate up to 1,000m... and beyond!
This long-range performance is achieved by using quality LEDs, Dereelight's own LED driver and a specially designed aspherical lens. Choose between a Cree XR-E or an XM-L LED - each with a voltage range of 3.4v - 12v. The XR-E LED will throw the farthest (up to 1,000m+) and tightest beam, whereas the XM-L will provide a wider beam, but still with a tremendously long range.
The XSearcher comes with an extension tube to allow an additional 18650 battery or another two CR123A batteries to be used. Using the extension tube will allow you to gain maximum power and runtime.
With a fully adjustable beam (from spotlight to floodlight) and multiple modes, you can customise the light output for every situation. With the XSearcher you can now see what you’ve been missing!
Main Features
Convex Lens: Specifically designed to boost the light power and throw a beam very far.
Focus: The convex lens can be focused to provide the best lighting for your situation.
Changeable LEDs: If you prefer to use coloured light, you can easily fit a red, green or amber LED into your XSearcher for long distance coloured illumination. The coloured LEDs do not reduce the light output like torch filters do.
Two stage lighting: You can have it outputting just 1 mode or 3 modes (High-Med-Low), just by twisting the body
Memory: If using the 3-mode function (High-Med-Low), the light will remember the last mode used
Lightweight, high power: This makes it ideal for all outdoor search tasks.
Specification
LED: High power Cree LED with both 1 and 3 mode settings.
Battery: 2x CR123A/ RCR123, 2x 18650 or 4x CR123A
Function: There are 2 levels of lighting - 1-Mode and a 3-Mode. You can switch from 1-Mode to 3-Mode by loosening the body of the light against the neck section. In 1-Mode, high output is activated when the tail switch is pressed. In 3-Mode, you can half press the tail switch to change mode (High-Med-Low). Automatic memory remembers the last function. This gives instant access to your preferred mode.
Switch: Protruding foward clicky tail switch with momentary-on function. The switch has a glow-in-the-dark (GITD) cover for easy identification at night.
Protection: Sealed with O-rings for excellent water resistance and improved service life. Waterproof and Dust Resistant to IPX-8.
Tactical: A removable grip ring offers better grip and an option to attach a lanyard or body sling. Remote pressure switch is available if you wanted to gun mount the XSearcher.
Dimension: 176mm (L), 70mm (Head), 25mm (Body Dia)
Weight: 335g (without battery)
Finish: Rugged body with HA Type III anodising.
Lens: Specially designed convex lens for maximum beam throw and adjustability - the beam can be focused to your shooting requirements.
Operation
- Turn Power On/ Off
Pressing the tail cap switch will Turn Power On/ Off.
- Switch Mode
1-Mode is full power during momentary-on and full-on. 3-Mode is High-Med-Low. Simple UI - half press tail switch to preview each mode and full click to select a mode.
- Focus Beam
The XSearcher beam can be focused from spot to flood. To adjust the beam, simply twist the head of the light to gain your required level of illumination.
- Memory Function
When torch is on in a preferred mode, click off with tail switch. The torch will remember the last mode when next switched on.
- Lock-out
Loosen the tail cap for full lock-out to prevent accidental activation.
(source: taclight)
click images for higher res
Dereelight XS 2MT-M, XM-L U2 vs Sunwayman T20CS
more pictures, incl beamshots coming soon
gopajti вне форума   Ответить с цитированием Вверх
Время генерации страницы 0.11719 секунды с 15 запросами
