2707
Регистрация: 04.01.2013 Последняя активность: 29.09.2015 22:48
Поблагодарили: 85 раз(а) в 24 сообщениях
Official site
http://www.mybalder.com/pro... Features - Multi-colors choice. Available to the colors of Black, Grey, Green and Sand - Titanium Strike Bezel on the tail end. - Compatible with Balder Magnet Clip. - Mil-Spec Type III Hard Anodized finish. - Made from Aluminum alloy, really strong. - Water proof to IPX-8 standard. - Precision Aluminum reflector (Orange Peel) - Simple operation. High-Medium-Low. No SOS and strobe modes - Twisty switch - Anti-reverse protection. Specifications: 1. Dimension: Head diameter 14.5mm, Tail diameter 14.5mm, length 75mm 2. Cree XPG R5 LED 3. Lumen and runtime (manufacturer rated): Single AAA: Maximum output of 140 lumens for 35 minutes Medium output of 36 lumens for 2.2 hours Minimum output of 1 lumens for 27 hours Single 10440: Maximum output of 252 lumens for 32 minutes Medium output of 90 lumens for 1.7 hours Minimum output of 16 lumens for 10 hours 4. Material: Aircraft Aluminum Alloy T6061 5. Weight: 40g (without battery) 6. Water proof to IPX-8 standard 7. Battery: single AAA or 10440 battery 8. Accessories: O-rings (2pcs), user’s manual my impressions Pros + Very nice build quality, anodizing, color + Smooth threads + Ti strike bezel + Perfectly centered led + 10440 Li-ion battery support + Available in three leds: XP-E, XP-G, XP-G2. (manual says) Cons - visible pwm flickering (low and medium mode) Other Unfortunately, I don't have 10440 li-ion battery at now. click images for higher res ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Balder TD-0 vs Olight i3 ![]() Balder TD-0 vs Fenix E01 ![]() more pics coming soon.. |
