Просмотров в теме 3978   Ответов в теме 0   Подписчиков на тему 0   Добавили в закладки 0
Старый 20.05.2014, 14:05 Автор темы   1
Аватар для gopajti
Последняя активность: 29.09.2015 22:48
Поблагодарили: 85 раз(а) в 24 сообщениях
По умолчанию *Pictures* Jetbeam DDR26 (1*18650, XM-L2, rechargeable,
Hello guys, Jetbeam DDR26 arrived (from lanternetactice.ro). Here is my impressions, pictures, beamshots
infos from official site
DDR26, a rechargeable digital display flashlight, is the world's first LED flashlight with digital display of the brightness and the remaining power level. It is under the patent protection of JETBeam’s unique digital display design. With the display function, the users can see the mode and remaining power clearly at any time. DDR26 can be charged directly. It offers three brightness levels and one strobe mode with an easy operation regulation of side control switch. It adopts the latest American Cree XM-L2 LED, max 1000 lumens, 70 hours run time. DDR26 extended the classic of RRT2 and became another miracle “rechargeable digital display flashlight of 1000 lumens”
1. Light source: Cree XM-L2 LED
2. Battery: 1*18650 (rechargeable) / 2*CR123 (non-rechargeable)
3. Output & Runtime: 1000lm (2h), 200lm (15h), 15lm (70h) strobe (1000lm)
- Beam distance: 280m
- Intensity: 12500cd
- Waterproof: IPX-8
4. Output regulation: Side switch
5. Circuit design: Constant current circuit, constant brightness.
6 Working voltage: 3 - 6V
7. Waterproof: Certificated to the IPX-8
8. Body: Stainless steel and aerospace aluminum
9. Dimension: 144 mm (L ) x 38 mm(D), weight: 144 gram (without battery)
http://www.jetbeamlight.com...
**UPDATED SPECS** confirmed by Jetbeam
Peak Beam Intensity: 10276cd (max. 230m)
Medium mode runtime: 200lm (8h)
My impressions
Pros
+ top build quality
+ perfect scratch free anodizing, nice color
+ smooth, good lubricated threads, o-rings are perfect condition
+ absolutely dust free, clean reflector and lens
+ perfectly centered led
+ long batteries fit perfect (eg. XTAR 18700) and you can use unprotected/flat-top cells
+ unprotected battery doesn't rattle
+ the best looking cool white tint what I have seen, better than my other lights (no blueish spill)
+ the side switch is better (better feeling) than SWM, Spark, Olight, Rofis, Nitecore switches, with excellent reaction time
+ the digital display is the most useful feature what I have seen, especially when I use unprotected battery, very helpful
+ rechargeable (USB) (cable length ~99cm)
+ no visible pwm or other irritating flickering, all modes are perfect!
+ no buzzing/humming sound
+ tail-stand capable
+ simple but nice packaging
Cons
- nothing significant (no holster, no charging port cover)
Other
My results
high mode total runtime (continuously): Start voltage: 4.18V, runtime 3h 7m 12s, end voltage: 3.21V (after few minutes 3.27V)
high mode (only "1000lm" without step down):
Start voltage: 4.18V, runtime 2h 2m 21s, end voltage: 3.21V
medium mode, total runtime:
Start voltage: 4.18V, runtime 9h 39m 10s , end voltage: 3.18V
Charging time: 7h 48m, 3.27V -> 4.18V
XTAR WP2 II (1000mA) charging time: 5h, 3.25V -> 4.19V
I used brand new unprotected Panasonic NCR18650B, 3400mAh battery.
More details coming soon
I have many 1*18650 flashlight but, the DDR26 is the one of the best 1*18650 flashlight for me at now. The digital display is much better than simple battery indicator or similar solution. Always show the charge level when the flashlight is on. I highly recommend this flashlight.
more pictures, other impressions (charge function, real runtime chart with brand new 3400mAh battery) coming soon
click images for higher res
DDR26 vs Sunwayman C20C
DDR26 vs Skilhunt K11
DDR26 vs Spark SL6S-740NW
DDR26 vs Xeno F42 V2 R5nw
DDR26 vs Rofis TR31C
DDR26 vs Sunwayman T20CS
DDR26 vs Nitecore MT26
DDR26 vs Nitecore P25
DDR26 vs Microfire TL2 T6
DDR26 vs Fenix TK35 U2
DDR26 vs Armytek Barracuda (XM-L U2)
gopajti вне форума   Ответить с цитированием Вверх
G.I. (29.10.2014)
Время генерации страницы 0.09709 секунды с 15 запросами
