Просмотров в теме 4205   Ответов в теме 0   Подписчиков на тему 0   Добавили в закладки 0
Старый 20.05.2014, 14:04 Автор темы   1
Аватар для gopajti
Последняя активность: 29.09.2015 22:48
Поблагодарили: 85 раз(а) в 24 сообщениях
По умолчанию **Pictures** Fenix TK75 (3*XM-L U2, 2600lm, 92000cd)
Hello guys, TK75 arrived few days ago.. here is my impression and pictures :wave:
Official website
http://www.fenixlight.com/v...
Features
  • Maximum 2600-Lumen Ultra High-Intensity Searching Flashlight
  • Utilizes three Cree XM-L(U2) LEDs with the individual reflector respectively with a lifespan of 50,000 hours
  • Incredible 606-meter beam throw
  • Over 8-day run time, suitable for long-time searching
  • Over 80-degree flood beam angle to provide a panoramic view
  • 4 brightness levels (Low: 18 Lumens, Mid: 400 Lumens, High: 1100 Lumens, Turbo: 2600 Lumens), Strobe, and SOS
  • Compact and portable so easy to carry
  • Intelligent Memory Circuit
  • Over-discharge protection circuit
  • Capable of standing up securely on a flat surface as a candle
  • Uses four 18650 rechargeable Li-ion batteries when needed but also can be powered by two 18650 rechargeable Li-ion batteries
  • Run time can be extended with the addition of a body tube segment and battery holder (sold as an accessory kit). Run time will double with each segment-holder addition but brightness levels will not change.
  • Waterproof to IPX-8 standard, underwater 2 meters
  • Stainless steel bezel
  • Toughened ultra-clear glass lens with anti-reflective coating
  • Dual button switch system on the neck for quick switching
  • Type III hard-anodized finish
  • 185mm (length) x 52.5mm (diameter) x 87.5 (head)
  • 510-gram weight (excluding batteries)
  • Digitally-regulated output: maintains constant brightness
  • Low-voltage warning function to alert users to replace the batteries
  • Reverse polarity protection guards against improper battery installation
My impressions (you know my english is not perfect but I hope understand)
Pros
+ Nice package (box), easy to carry
+ Very good build quality as always
+ Beatiful reflectors without dust, bubbles etc.
+ Dust free lens (inside)
+ Good looking matte SS bezel
+ Comfortable switch position
+ Strong battery holder with strong springs (no rattle in the flashlight)
+ long, "18700" batteries can fit, I tried XTAR 18700, 2600mAh (but flat top batteries, eg. Fenix ARB-L2, fit more easily)
+ Nice cool white tint. (lower modes are creamy white), no rings on the wall
+ Extreme long runtime (18lm/200h), especially with extra extension tube
+ The 18 lumen mode is very useable (incl. outdoor)
+ Excellent regulation, constant brightness (in all modes)
+ No PWM or any other irritating flickering (in all modes)
+ Silent driver (in all modes)
+ Powerful long throw
+ Stable tail stand to serve as a candle
Cons
- One led is not quite centered, but I can't see any artifacts in beam (incl. close wall shot)
Other
TK75 review (candle lamp)
Fenix ARB-L2 18650, 2600mAh (3.6V) battery review (HKJ)
Fenix ARE-C1 li-ion charger review (HKJ)
and now, the pictures, click images for higher res (I will make more beamshots, but the weather is not too good at now)
Fenix TK75 vs Fenix TK35 U2
Fenix TK75 vs Blackshadow Terminator (4*XM-L T6 NW)
Fenix TK75 vs Olight SR51
Fenix TK75 vs Armytek Barracuda, XM-L U2, 5500K
Control vs Fenix TK75
Fenix TK75 vs Nitecore MT26
Fenix TK75 vs Spark SL6S-740NW
Fenix TK75 vs Lumintop Hunter T5 (XP-G2 R5)
Fenix TK75 vs Microfire TL2 T6
gopajti вне форума   Ответить с цитированием Вверх
Время генерации страницы 0.13318 секунды с 15 запросами
